I have a Crystal 2 inlet feeding the usual sink, bathroom & shower, and also the Thetford cassette,
The water flow wasn't particularly good so I removed the non-return valve fitted to the Crystal inlet, and put a larger diameter Whale non-return valve in the feed pipe next to the Crystal housing.
Bingo - the flow was much improved, and the problem was solved.
But (isn't there always a 'but'?) When I removed the water pump from the external socket I noticed a trickle of water coming from the inlet pipe.
I assumed that it must be a residue from the cartridge - but it continued to trickle out for several hours, emptying the boiler and interior pipework.
As the only way it could come out was past the non-return valve, I assumed that it must be faulty and changed it for another one.
The problem continues - and it's unlikely (but not impossible, I suppose) that both brand new whale valves are duff. The valve *is* fitted the right way around
Has anyone any other suggestions? - the water is definitely leaking out of the supply inlet - the same way it went in, but in reverse, and very slowly.
All connections are tight, no leaks inside the van, no spluttering or signs of air once the system has been filled and run - just the annoying discharge of water once the pump has been removed.
Your thoughts appreciated
