CVT automatic transmission
Aug 29, 2015
Does anyone have experience towing with a CVT automatic transmission as found in RAV4, Qashqai or other models? Reliability? Performance? Noise?
Apr 16, 2015
9
hi Roger
I tow a Bailey unicorn Seville 2012 with my Rav 4 2.2 deisel auto no problems at all I find it is easier when using the flappy paddles than the auto setting you can control the gears easier and demand more torque by gear selection when required. not so sure about it being a CVT transmission though just 6 speed auto with manual selection and flappy paddles or gear lever shift and sport button selection.
Bob
3,919
Hello Roger,
As Bob has pointed out, its not clear which model of car you are specifically concerned with. I have just done a basic search to find out if the RAV 4 is offered with a CVT, and unless they use a different name for it I cant see it mentioned.
Please tell us exactly which year and model (full title) you have in mind, then we can do a bit more research
Aug 29, 2015
Hi
I read in an online review (can't remember which one) that the RAV4 has a CVT auto box but I can't find any info from Toyota. Even the owners manuals do not say what type of transmission they have but it seems there are two versions for the 2012 models, 4 speed and 6 speed. I am looking for a petrol automatic and checking out various makes at the moment but I am having great difficulty finding technical data on most makes. It seems they don't want us to know too much these days!
Thanks for your input. Thanks also to Bob. Carrying on with my research . .
Roger
Oct 17, 2010
1,284
526
19,435
CVT gear boxes don't have a fixed number of gears ie 4 or 6, they have an infinite number of ratios through its range. I was a wood machinist and some machines feed speeds were adjusted by variable seed pulleys, manually operated, if you wanted to change the feed speed, winding the adjuster wheel, opened or closed the distance between the pulley plates , either closer together or further apart, allowing the drive belt to alter its position on the pulley thus increasing or slowing the pulley altering the feed (revs) speed, whilst allowing the drive motor to run at a constant rev's . Simplistic I know, but it's how these CVT work and it's only way I know to help me understand these gearboxes . I will now gird my loins ready to be shot down in flames :woohoo:
3,919
Hello
I have always been a bit sceptical about CVT transmissions in cars, Historically the first ones I heard about were in a DAF cars (remember the Daffodil's?) Stories of a dealership with a yard full of Dafs with broken transmissions waiting for spare parts. snapped or worn belts, or damaged cones.
I had the opportunity to use a Ford Cmax 1.6L Diesel with CVT a few years ago as a courtesy car, essentially it adjusts its transmission ratio so that for any given speed the engine should be at it optimum RPM. It can make the car sound counter intuitive as when accelerating the engine speed barely changes yet the speed the countryside passes increases.
It seems that many manufactures have toyed with CVT's but generally only on smaller models which never seem to be produced for very long before they revert to a more conventional gear box.
What I don't know is if it's down to unreliability, of the buying public shying away from them. Either way it's this transitory flirting with the technology that increases my suspicion they are not fully developed and therefore a bit fragile.
If they are susceptible to failures in standard cars, I have serious doubts about its reliability when coping with the additional load of towing.
Until there is much harder evidence that the technology has matured, I will not consider on for a tow vehicle.
Aug 29, 2015
Yes, that's as I understand it too. But to confuse the issue some CVTs, eg. Subaru have a mode which uses a number of fixed ratios too, which I presume are just presets.
Aug 29, 2015
Thanks for the link. Richie75's case is scary! Potential economic write off after end of 5 year warranty!
3,919
The Cmax did have a selector which as you suggest may have been presets, but it was from memory not really like conventional gears, though it did allow you to select a higher ratios for some engine braking on descents.
Jul 22, 2014
329
One of the smaller Jeeps had CVT as an option, the Patriot/Compass (same mechanics, different body). People hated it.
Aug 11, 2010
1,362
reliability of cvt systems is fine no worse than any of the new electronic semi autos that are around and although i beleive there is too much hype concerning Dual mass flywheels failure a cvt would be no worse than that. like so much of today's technology they have serviceable parts and a service life and of course it isn't cheap to change anything on a transmission these days. "apparently" its the most efficient system to have in today's age of lower co, better mpg ..wife had it on her 2000 model punto speedgear proved reliable for the 50 odd k she had the car for. not for me at the moment simply because its not fitted to anything i like but no doubt it is here to stay given its advantages ,heck it was banned from F1 back in the 90s because it had such an advantage for those that could afford investing in the technology over those that couldn't.. its potential is huge ....
Jul 22, 2014
329
JonnyG said:
"apparently" its the most efficient system to have in today's age of lower co, better mpg .. ... heck it was banned from F1 back in the 90s because it had such an advantage for those that could afford investing in the technology over those that couldn't.. its potential is huge ....
An infinitely variable ratio such as the CVT provides is bound to be more efficient because at any moment the ratio can be optimised for efficiency as computed by the Engine Control Unit.
However, such marginal efficiency savings will be wiped out many times over by the massive repair costs if the thing goes wrong.
As is often the case, the efficiency savings are aimed at the first two years of life, with the loss being in the expense of maintaining the car later on. There is probably a net loss in "green" terms, but as companies usually replace their cars after 2 or 3 years, such devices help them perform the "green" posturing that is required of them these days.
Aug 11, 2010
1,362
does sound like you could be talking about any new technologies being used in modern vehicles today, be it injectors, fuel pumps. DMF, DPFs semi electronic autos , dsg boxes .. ect ect..
Jun 2, 2017
141
yeezy boost 350
jerseys cheap
coach outlet online
heat jerseys
phillies jerseys
cowboys jerseys
hermes bags
discount nike shoes
oakley sunglasses outlet
michael kors outlet store
louis vuitton bags
yeezy boost
mont blanc pen
michael kors outlet
adidas uk
birkenstock outlet
louboutin pas cher
nike outlet
toms
burberry outlet online
kate spade handbags
purs jerseys
adidas outlet store
cheap jerseys
toms
coach factory outlet online
cheap nike sneakers
nfl jerseys
louboutin outlet
longchamps
air max outlet
ralph lauren sale
adidas running shoes
coach handbags outlet
birkenstock shoes
coach outlet online
true religion
pandora charms
fitflop shoes
nike outlet store
ralph lauren outlet
adidas nmd r1
yeezy shoes
air max
nike outlet store
coach outlet online
michael kors
coach outlet store online clearance
hermes bag
kate spade bags
moncler uk
versace
cheap jordans for sale
prada outlet online
ralph lauren outlet online
louis vuitton factory outlet
gucci borse
mont blanc pen
swarovski sale
coach outlet online
kate spade outlet online
mulberry uk
coach purses
jordans
tory burch outlet online
adidas outlet online
giants jerseys
adidas nmd runner
gucci outlet online
adidas nmd runner
adidas outlet store
yeezy boost 350
beats by dre
rolex replica watches
nike outlet
moncler uk
gucci handbags outlet
ralph lauren sale
coach outlet store
kd shoes
cheap jordan shoes
polo ralph lauren outlet online
sac longchamp
burberry outlet store
ralph lauren outlet
kate spade outlet store
harden shoes
pandora jewelry
pandora charms sale clearance
michael kors handbags outlet
polo ralph lauren
christian louboutin
dansko outlet
texans jerseys
ralph lauren sale
fitflops
fendi bags
air max 90
dodgers jerseys
eltics jerseys
louis vuitton outlet online
longchamp bag
rolex replica watches for sale
chaussures louboutin
nike free 4.0 flyknit
rolex watches
coach outlet store
yankees jerseys
montblanc
pandora charms
fitflops sale clearance
pandora
coach outlet online
nike free run flyknit
nfl jerseys cheap
curry shoes
ray ban sunglasses outlet
christian louboutin outlet
adidas nmd runner
nike air max 95
marc jacobs
christian louboutin shoes
adidas ultra boost
ray ban sunglasses discount
cheap jordan shoes
adidas superstars
hermes outlet online
oakley sunglasses on sale
cardinals jerseys
michael kors outlet clearance
abercrombie outlet
marc jacobs outlet
hermes outlet
cheap rolex watches
pandora charms
air max 90
nike free run
nike outlet store online
longchamp handbags
yeezy boost
true religion jeans
ralph lauren sale
tory burch sale
coach outlet online
fitflops clearance
air max
cheap jordan shoes
michael kors outlet online
nike sneakers
coach outlet online
yeezy boost 350
louboutin outlet
coach outlet online
gucci outlet online
air jordans
coach outlet store
discount oakley sunglasses
moncler pas cher
polo ralph lauren
mulberry bags
sac louis vuitton pas cher
coach outlet online
ray bans
michael kors bags
adidas
toms outlet
coach outlet store
michael kors
mont blanc pens
broncos jerseys
sac louis vuitton
birkin handbags
swarovski uk
fake rolex watches
clarks shoes outlet
wireless beats headphones
salomon boots
birkenstock outlet
ralph lauren
jordan shoes
fit flops
coach outlet store
louis vuitton outlet store
adidas nmd r1
gucci
red bottom shoes for women
mulberry handbags
adidas nmd r1
christian louboutin sale
swarovski crystals
ralph lauren outlet
rangers jerseys
mulberry outlet uk
mlb jerseys
true religion jeans outlet
pandora jewelry outlet
fitflops clearance
beats wireless headphones
burberry sale
bercrombie
tods outlet
fitflop shoes
cheap nike shoes
cheap nfl jerseys
kd 8 shoes
salomon outlet
nike outlet online
burberry outlet
michael kors bags
jimmy choo shoes
ed hardy store
fred perry polo shirts
cheap oakley sunglasses
valentino outlet
pandora charms outlet
air max shoes
nike store
dolce and gabbana outlet online
yeezy boost
toms outlet
fitflops sale
michael kors outlet canada
nike roshe one
gucci
49ers jerseys
moncler jackets
mbt
michael kors
ralph lauren outlet
adidas
yeezy boost 350
nike air max
yeezy 350 boost
michael kors bags
ralph lauren
patriots jerseys
adidas nmd r1
michael kors uk
coach outlet online
nike blazer low pas cher
pandora bracelet
nike air max 95
red sox jerseys
gucci bags
coach outlet online
air jordan shoes
nike flyknit
christian louboutin
mulberry uk
moncler outlet online
levis outlet
toms
nike roshe shoes
longchamp soldes
longchamp outlet store
hollister clothing
coach outlet canada
lakers jerseys
kate spade uk
longchamp bags
michael kors
ralph lauren sale clearance uk
moncler jackets
chi flat iron
jordan shoes
hermes bags
polo ralph lauren
mulberry
ralph lauren
clarks shoes outlet
coach outlet online
nfl jerseys
coach outlet
michael kors
mlb jerseys
adidas sneakers
longchamp bags
adidas store
hollister kids
beats headphones
nike cortez classic
tigers jerseys
warriors jerseys
pandora jewelry
salomon outlet
cheap air jordans
longchamp pliage
nike air force
michael kors outlet
louis vuitton purses
michael kors
nfl jerseys wholesale
adidas superstars
packers jerseys
longchamp handbags
fitflops sale
michael kors
red bottom
pandora outlet
white sox jerseys
fitflops sale
mbt
air max
clarks
nmd adidas
cheap ray ban sunglasses
coach outlet online
adidas yeezy boost 350
burberry outlet
cavaliers jerseys
air jordans
adidas sneakers
true religion outlet online
fred perry shirts
adidas trainers
polo ralph lauren pas cher
cheap jordan shoes
pandora jewelry store
red bottom heels
eahawks jerseys
ed hardy outlet
coach outlet online
louboutin shoes
nike uk
clarks shoes for women
parada bags
longchamp sale
yeezy shoes
bulls jerseys
moncler coats
nike outlet store
vans outlet
vans store
timberland boots outle
ray ban glasses
christian louboutin pas cher
cheap jordan shoes
rolex watches
jordan retro
yeezy boost
oakley sunglasses wholesale
nike tn pas cher
jordan femmes pas cher
rockets jerseys
cheap rolex replica watches
adidas nmd runner
montblanc pens
coach outlet online
gucci bags
birkenstock uk
adidas yeezy boost
thunder jerseys
jordan uk
louboutin outlet
birkenstocks
sac longchamp
ghd straighteners sale
adidas yeezy boost
coach outlet online
fitflop
adidas yeezy boost
birkenstock
celine outlet online
air max 90
fitflop
birkenstock outlet
ed hardy clothing
nike sneakers
fit flops
louboutin shoes
ray ban sunglasses cheap
ed hardy uk
adidas trainers
ralph lauren
chaussure louboutin pas cher
ghd hair
nike air huarache
ray bans
yeezy boost 350 v2
ray ban glasses
coach outlet online
coach factory outlet store
adidas superstar trainers
michael kors
polo ralph lauren
adidas superstar shoes
mlb jerseys whgolesale
pandora charms sale
tods shoes
birkenstocks
celine handbags
yeezy shoes
red bottom
kate spade outlet
kate spade bags
mbt
fitflops sandals
mlb jerseys
coach outlet online
cheap air max
longchamp bags
dansko
adidas sneakers
michael kors uk
adidas yeezy boost
cubs jerseys
ralph lauren uk
coach outlet online
fit flops
louboutin outlet
kate spade purses
pandora charms sale
rwfwreft
