Debris on floor
Apr 20, 2024
21
515
Hi, does anyone know where these are coming from.
Hoover up every week, and these reappear on our return every week?
Thought they were off the next curtains, but they’re not
Thanks.
Jan 20, 2023
1,271
1,114
2,435
It could be bits of insulation blowing in from somewhere. Possibly as wind blows through the floor drop vents it's blowing bits in from underneath the settees? What sort of material is it?
Apr 20, 2024
21
515
Hi, it does look like some sort of filter and when pick it up and you rub it with your fingers it disinter grates…
Jan 20, 2023
1,271
1,114
2,435
Sometimes a caravan will have something added (external socket etc) which leaves bits of shredded polystyrene hidden in various areas, the same thing can happen when it's assembled. When a draught blows through from underneath it can blow these bits out onto the floor. Try squeezing it between your fingers, if it is lightweight/polystyrene then that's probably where it's come from. If it's some sort of grit then I really don't know, sorry.
Feb 23, 2024
90
57
635
Looks like the backing to wallboard or some sort of fabric. Seen stuff like this on the inside of PU leather chairs. Dunno though
4,227
I have something similar in our back bedroom at home. It turned out to be from inside of the curtains, where they are stitched together.
2,467
By looking at it does look like bits of polystrene i would investigate in your caravan you might find some more good luck
