Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
We’re currently investigating an issue related to the forum theme and styling that is impacting page layout and visual formatting. The problem has been identified, and we are actively working on a resolution. There is no impact to user data or functionality, this is strictly a front-end display issue. We’ll post an update once the fix has been deployed. Thanks for your patience while we get this sorted.
any advice on removal of old decals from caravan before fitting new. area decal`s are on are glass fiber and another one of aluminium thank`s in advance, terry baker
Hi Terry, Warm the decals with a hairdrier,as they warm up the adesive should soften enough for you to peel them off,any surplus adesive can be removed with a suitable solvent.
Terry, warm gently with a hot air gun on low, gently pull away from the van at 90 degrees, warming as you go. When applying the new decals it helps if you spray the van with soapy water first, it allows you a bit of movement if you don't get it in the right place first time.
