- Jul 22, 2014
- 329
- 0
- 0
I am trying to repair a Thetford toilet. It is not flushing and I suspect one of the microswitches has failed, or it may be the pump. I need to get the fresh water tank, pump (which I guess is inside the tank), and operator switch/shutter mechanism unit out.
Has anyone done this? It is not obvious how it comes out. The first problem is getting the operator switch/shutter unit out (1st photo) ; is there a screw under that centre or can the knob be levered off upwards, revealing some method of freeing the rest of the switch/shutter unit?
Even after that, and presumably after removing the screwed-on external fascia (Photo 2) there would still seem to be quite a lot obstructing the tank from just sliding out, such as the level indicator. Is this something the manufacture banged together with irreversible plastic barbs like so much other stuff these days?
I shall be having a go at this, will report results, but any advice first will be appreciated.
