Do anyone know where is fuse box or battery fuse location on cristall moorea 530 EB 2007?
Sep 23, 2023
1,403
613
2,435
20 amp yellow fuse is usually around the battery try to follow the red cable from the battery, mines under a cover under the wardrobe.Which fuse box?The 240v mains?
Aug 4, 2025
I can not find any fuses. there is 240v mains, but Lightnings work on 12v. no power coming from battery.
Jul 15, 2008
3,913
1,099
....there is convention in fusing caravan batteries.
That is to fit the single fuse in the positive feed wire from the battery as close as possible to the battery.
Look for wires from battery terminals entering caravan at the back of the battery box.
Locate this entry point inside caravan ....follow the wires looking for a fuse.....usually a blade fuse.
This should be within 0.5meters and often obscured by other fittings and components.
4,631
I think caravan wiring installers, do a special course, in hiding the main fuse.
Some folk mistake the Motor mover fuse for the caravan battery main fuse.
Reactions: toad a caravan
9,212
Are continental built caravans the same as UK wrt this cabling? Could it be a UK owner installation?
