Does any one else do this??.
Mar 27, 2011
1,332
507
I knew they had different products for different jobs but I didn’t realise just how many, thanks for providing the link OC.
2,627
I would have agree thanks for the link OC i did know they had so much in the product range very interesting information .
Mar 28, 2007
67
18,585
You can get the proper kit to blow the water system though. But that's overpriced in my opinion. I did make a mock up once with a bellows pump but all I do now, and it works. is:
  • Drain down as much as possible.
  • Close all taps.
  • Remove shower head. Put shower control open and to mid position
  • Open nearest tap to the shower, midway between hot and cold.
  • Blow through the shower hose until you get free air from that tap.
  • Repeat with all taps ending with the drain tap.
If you have mains electricity available I use my aqua vac cleaner and suck the stuff out instead of blowing through
5,362
I don't think I would be too keen on "sucking" out any water with a machine as the pipes can only withstand so much pressure?
1,819
We have always managed by blowing down the taps although you do need to be a bit of a contortionist at the sink.
2,627
i don"t think i have enough puff for blowing down a shower hose or shower head to get water out . i let a caravan engineer do it for me .
9,321
No risk of under pressuring hoses by Sucking as you can’t get more than a zero vacuum at minus ambient atmospheric. So 15psi approx. But if pipes are designed for pressure they could collapse inwards. Very unlikely though methinks 😂
4,393
Floe and drain blows air out while the other device sucks it out. Is there a possibility that if it sucks too hard it may collapse a pipe as you cannot regulate the vacuum??
I seriously doubt it would collapse the hoses, but it could conceivably affect a water heater tank.
But some "O"ring seals are designed to be pressure activated, and exposing them to negative pressures might compromise their future action, so sucking is not a good idea.
5,362
I am not sure but maybe it could affect a one way valve?
2,743
Sucking the pipes out should only cause a slight vacuum as to work the taps would have to be opened to vent the system. If they were not, I don’t think that a domestic machine could achieve anywhere near a sufficient vacuum to collapse the pipes. But ‘O’ ring seals might but more problematic as the Prof says.
If I had power on the storage site I would do it. Except my carpet cleaner is kept in the loft, not too handy.
925
240
19,135
I thought I was odd man out regarding vacuum out the pipes as we have done it for years. What I never thought of was possible collapsing pipes and as mentioned O rings.
