Does anyone actually reverse onto a pitch?
Oct 17, 2010
1,290
535
19,435
Eatcustard said:
I have never reversed onto a pitch, only used a mover, I value my clutch :)
This is where an automatic gear box is a god send, reverse gently and slowly, very little wear and tear.
Feb 26, 2015
18
That I agree, but at the loss of fuel economy.
Jan 24, 2015
187
I reverse on whenever I can ..... it's all part of the fun and I have no shame in providing some entertainment for others!!
Mrs Keith is pretty good at guiding me ..... she's even better when she remembers to stand where I can see her in the mirrors!! :cheer:
I tend to use the movers to adjust and get up the levelling ramps if we need them.
Apr 10, 2016
117
New boy here.
Is there no fraternity amongst caravaners. When I see a driver having trouble backing onto a loading bay, I get out of my cab and act as his banksman.
4,011
Tenpole, yes there is a lot of comarardery between caravanners, a lot of the time I have found, its best to leave the pitcher and their partner to sort it out unless they are in real trouble, then offer help, it can cause friction to the couple afterwards I have been told, and I am always happy to help pull a motorhomer out of the mud,
Apr 10, 2016
117
Ha my father was a motorhome enthusiast. He did not like caravans, but for me I think it makes more sense to have a caravan then you have a vehicle to go shopping/exploring and a larger living space.
You saying that about pulling motorhomes out of the mud reminded me of times as a child back in the 70's/80's and the camper bogging down in a field.
Oct 17, 2010
1,290
535
19,435
Not an excessive amount, in this day and age, more than balanced out with the relaxed drive, partially in heavy traffic and they are more forgiving than a manual gear box/clutch, I have never missed that third peddle. :) :)
Feb 26, 2015
18
The Mondeo has a huge difference from manual to auto (about 9mpg) for a 2l TDCI
That means I will stick the manual Mondeo for now :)
4,011
When we were about to purchase our new car, a Sante Fe, I decided that we would go for the manual as it had a higher tow load 2500 kg, but whilst putting the caravan away into storage, with our auto Santa Fe, I thought do I really want to be towing with a manual. NO, Changed my order to the Auto, never regretted it.
Mar 22, 2012
84
15
18,585
We recently collected our new Hyundai santa fe auto from the dealers and went out with the van in tow at easter.This is our first auto box and I found it a lot easier to reverse the van onto the pitch on that occasion, but generally use the motormover for the fine movements needed to line up the Alko wheel lock
4,011
Bluerocket, Hope you find your SF as nice as mine, a SE.. I had a problem with the Witter Towbar as fitted as Original Equipment, through dropping ,. But yes a nice tow car and great for reversing. Same with the Alko wheel lock.
Mar 22, 2012
84
15
18,585
I asked the dealer to ensure the witter detachable towbar had the nylock nuts fitted to prevent it dropping and rubbing on the spare wheel when towing as I have known about this prior to purchasing the car. so far we have had no problems but best to keep an eye on it methinks
4,011
Sorry mine was the fixed flange,
Yes, I eventually changed mine to a tow trust one, another forum member on his Kuga, after complaning to Witter about "Not looking right" Witter admitted the hitch from the cross member to the flange was wrong. See my posts on Caravan club about SF tow bars. After fitting new nylock nuts and thread lock , and higher torque as recommended, my Witter bar didnt drop. But the TT bar was 2 inches closer to the car and 1 inch higher.
But my car is now 18 months old . A mk 3 64 .
Apr 20, 2009
5,611
1,015
Normally reverse if site is suitable, have had to in the past use the mover on 3 sites as the pitch's were side on and there was no way to reverse on to it.
Reversed on to a pitch last year and the 15 year old lad on the next pitch was watching, and when I got out he said that was a good bit of reversing, you did it first time.......I then preceded to show him the camera......
DAD,DAD you want one of these... No you dont you NEED one of these :)
Apr 10, 2016
117
I find reversing the caravan harder than backing up an 40' artic trailer. Maybe I should convert a container.
Oct 17, 2010
1,290
535
19,435
-I had the same conversation with a lorry driver when I was still working, he said a single axle van was harder to reverse than an artic, Mind you, when he did reverse a van, he could park the b----y thing on a sixpenny piece.
Feb 3, 2008
3,790
It's all down to geometry, a lorry cab unit has a short wheelbase relative to the long trailer length (and the pivot is within the cab wheelbase) whereas on a car the lengths are virtually equal meaning movements on the car are immediately echoed on the van.
May 24, 2014
3,687
765
When i first passed my Hgv, an old timer gave me one piece of advice. It was good then for artics and it still works for caravans. Its this simple
DO ALL THE HARD WORK GOING FORWARDS.
In other words line it up first. Jacknifing into position, especially blind side is making your task harder than i needs to be.
Jun 2, 2015
605
Easier said than done in many cramped pitches with little or no room to manoeuvre in front of the pitch. I do however follow that mantra at the storage facility where I can have the car and caravan in a straight line and just go backwards.
Feb 9, 2009
465
24
18,685
With a total length of about 40 feet for the car and van there is rarely enough room to reverse onto a pitch so it is mover 99% of the rime
Dec 30, 2013
694
I have done it several times, although I usually get hubby to do it. I call upon the Woosies as my witnesses!!
:woohoo:
4,011
Whist at work I used to tow and push Helicopters and Aircraft, but using tractors and Tugs from the front, dead easy but reversing a short trailer, very hard the shorter the coupling the harder it gets, but still fun.
