I have been told that if you leave a few dishes of salt in the van in winter it helps to absorbe any condensation, therefore helping to avoid damp. Has anyone else heard this, and if so does it work?????
i agree i have used salt in old ice cream tubs for many years and always find it works out a lot cheaper than buying expensive alternatives johnhi all
sorry JTS I would not agree salt is a very good moisture collector if you use enough, 2 cereal bowls (one front and one back) half full with salt will collect all the moisture from a van for about 4 weeks if left longer the bowls could over flow as it absorbs that much, I have been using it for years ever since silica gel became scarce.
colin
hi rogerP I just throw it away as salt is quite cheap but there is no reason why it cannot be dried out on a tray in a low oven once the liquid has been drained off, colinwhat do you do with the salt when its saturated?
juat throw it out or dry it out (if so how?)
