Does your Baileys D4-4 have this?? Bumps on wall above window!
Apr 27, 2025
26
8
35
Hi all,
I have a 2022 Baileys D4-4.
Last night when i had the spot lights on I noticed two bumps on the wall/ceiling above the front large window. They are in a similar placement either side of the window if you can make them out in the photo.
They may have always been there and I never noticed them as its only visible in a certain lighting.
They are solid to touch.. not damp or soft or anything.. so I'm hoping its not anything like that.
Does anyone have a Baileys? Or know how a caravan is built..Is it supposed to be like that? I cant see anything above the window on the outside but maybe it is the frame/structure of the inner caravan?
Ive never noticed them before but I only noticed the lights on my toilet last week too.. so its not unusual i didnt see them till now :ROFLMAO:
308
248
935
If its a plastic moulding they may be the 'sprue' marks. On injection mouldings , the molten plastic is injected in down one or more tapered holes in the mould. When the moulding is released from the mould the operative cuts off the excess plastic( which is known as a sprue) which has set in the hole(s) whilst the moulding is still hot and soft .This will leave a mark on the completed moulding , it always on the inside of the moulding so its not seen .Its possible the sprue wasn't cut off completely flat or the plastic was a little too soft the top surface can be deformed ( which it should have been rejected and sent for shredding ). It will interesting , now that you have pointed it out, whether other members start to notice the same marks on similar mouldings.
2,433
I be keeping a look out if we have to buy another caravan and will soon know might be visiting some caravan dealers next week thanks for the heads up on this .
Apr 27, 2025
26
8
35
Thankyou for explaining it so well.. i hope thats what it is and i do hope others have noticed them as im worried in case it is a sign of damp or anything bad! @Beachball ..If you are in any Baileys soon please have a look for me :D Altho in daylight it isnt really noticable but i can feel the bumps.
Jan 20, 2023
1,252
1,090
2,435
That looks like a typical delamination issue where the adhesive is missed in that area and you end up with an "air bubble" between the skin and insulation beneath (I had it on a previous Swift). Please discuss with your dealer as it will be a warranty claim and should be rectified before it gets worse.
Apr 27, 2025
26
8
35
Thank you for bringing this to my attention, id not heard of delamination before as a new caravan-er! From my small bit of reserch now tho im not sure this is what mine is as it seems it would be soft/damp if so?/ The two bumps on mine are solid! It feels like metal bars or something to me but i guess there isnt a metal caravan frame. I think the 3 year warrenty on this caravan runs out this month. i brought it 4 months ago from the 1st owner who has had it since new.. so unsure if i can claime on the warenty but if i need to i better do soon!
Apr 23, 2024
308
248
935
to me they are too symmetrical to be air bubbles , but I am open to be wrong . We need to accumulate evidence on more caravans to see if this a common issue or a one off , I will certainly be watching on caravans I visit for similar marks.
4,843
Did you transfer the warranty across into your name? The warranty, if transferred, is only for damp ingress. As you bought privately, you are probably on your own, but it may be worth asking a dealer of AWS technician if there is an issue. They may or may not charge.
Jan 20, 2023
1,252
1,090
2,435
No, the delamination is effectively the GRP skin coming away from the insulation rather than a wallpaper/thin decoration coming away, trust me, you cannot push in a delaminated bubble! Delamination is caused during the manufacturing process where the spray adhesive which bonds the inner (or outer) panel to the inner insulation core misses a bit, over time the air in this area expands and causes the "bump". Repair involves either replacing the panel of having adhesive injected into the problem area and the panel clamped tight while it cures. It will not feel damp OR be caused by damp.
I had it on a previous 2022 Swift, the bubble was around 12" long x 2" high, the repair (done by Swift themselves) was invisible.
