- May 12, 2014
- 90
- 7
- 10,585
I've got a roof-mounted Dometic air conditioning unit (Freshjet 2200) which came with my van. I've never used it in the year I've owned it as unfortunately the weather hasn't been hot enough to require it! We went away this weekend though and as it was cold in the evenings the day before we left I turned it on whilst the caravan was on the driveway to figure out how to use it in heating mode (it both heats and chills the air).
It had been on for around 1 minute when I started to notice a burning smell. I thought this might just be dust burning inside the unit (which I get with my gas Truma if it hasn't been used for a while) so kept a close eye on it but 15 seconds later the main breaker switch on the house electricity board flipped.
Switched off the air con at the main switch in the van, reset the breaker and everything else in both house and van is working fine. Anyone have any ideas of things to check? Having not used the unit in the year I've owned the van if it's something I can safely fix myself I'll have a go, but if it requires any outside work I'll probably leave it as a heavy non-functioning roof ornament for the time being at least!
