Dometic caravan fridge sticking gas valve.
Jul 11, 2021
13
4,515
I have a sticking gas valve on a Dometic caravan fridge.
I clear the problem by giving it a tap when this happens .
Is there any way to lubricate the gas valve without taking it apart?
4,027
In general there are no "serviceable" parts within a gas valve made to meet UK standards, because of the risk of leaks from damaged or incorrect parts. The valve should be replaced with all the work including the removal of the appliance to it's refitting carried out by a competent fitter. This should ensure you and your families safety.
Reactions: birdman101
Apr 23, 2024
279
215
935
You then have to think why the gas valve was sticking in the first place. The common cause is oil( known as 'heavy ends) in the pipework from the gas cylinder which may also be in the regulator. The regulator may also start to malfunction. I know it sounds contradictory as oil normally is a lubricant , but the forces required to open and close the gas valve are small and oil jams up the valve stem , it also can cause the rubber valve seat to swell, which is what causes regulators to jam up(closed) . Attached is a photo of an 18 month old bulkhead regulator which failed due to oil build up ( it was in a motorhome) . The gas bottle was one of the refillable types and I can only assume the filters at the filling station were not doing their job , The client has opted for having an oil filter fitted. Overfilling a gas bottle is also a source of liquid being injected into the regulator and pipework along with oil , also causing freezing of the regulator and pigtail as the liquid boils off with a limited surface area.
