dometic ectrolux fridge in freedom jetstream caravan no mains...
Sep 25, 2005
Our fridge failed to operate on mains on our last trip this year. The fuse trip is intact and the green light is on, on fridge mains switch. It works ok on gas 12v. Could the heat be faulty or thermostat? Are these easy to get at & check or change. Thanks your help would be much appreciated.
Sep 3, 2005
37
we had a similar problem and although the blade type fuse wasn't blown it was faulty we discovered it by luck
We had this on a new Electrolux and if you are under warranty they come to you FOC.
On our fridge it was a failed heating element.
www.dometic.com
