Dometic Ill fitting fridge door
4,768
Anyone know the solution to this fellow Forumite on Bailey Senator Owners Club
“Does anyone know if you can adjust the fridge door to close this gap?”
Jan 19, 2002
1,674
516
Looks much the same as my fridge in that when fitted it can be hinged left or right, and I think on mine I could still swap it over if I fancied it opening the other way. The owner therefore should be able to assess and hopefully correct the issue at the top hinge.
4,681
If it is a newer caravan it is a known problem, but cannot recall whether it is Thetford or Dometic that had issues with doors dropping?
