door hinges
May 15, 2007
40
the door higes on my van are tightening up, so when i open the door it puts a strain on the side panel, i have tried wd40 but it dosen't seem to penetrate--will i need new hinges??
Jan 2, 2006
2,431
Are they stiff if you open only the top or bottom and not the whole door,if so the hinges are out of line(not that likely)more likely water ingress around the door frame distorting the frame and causing the two halves to scissor.
