I have tried to drain this tank by opening the drain valve and taps without success, even after traveling. Air lock perhaps? Any tips to drain for winterising please.
Thanks Colin. I'll try that when I get to the caravan and let you know.hi jim
I've got the same truma heater which would not drain last year due to a blocked pipe
I managed to clear it by doing the following :- 1. disconnect the pump and turn off the electrics (12v) 2. open drain valve 3. close all taps 4. diconnect shower head from its pipe in the bathroom. 5. open hot tap to shower 6. blow down the pipe to pressureise the system in reverse.
it worked for me,
colin
