draw bar grease
good afternoon all just in need of some advice just doing a check on the van before we go away next wk does anyone know if their is a visual sign of the grease
coming out of the draw bar as you would when doing a knuckle joint to say that's enough or give it up till no more will fit
cheers
now sorted was advised if their is movement in the shaft keep pumping till their no movement push in /out a few times if movement repeat
