Driving with photo-chromatic transition lenses.
Dec 27, 2022
549
397
2,135
Last night was the first time driving for a long period (4hrs) at night on single carriageway roads* with my transition lenses. After about an hour I took them off and my vision was much clearer, distance prescription is 0.95 so almost nothing.
Not sure I will get transition lenses next time.
* It's Ireland and the motorways don't run from Rosslare to Lahinch apart from one bit round Limerick.
9,045
My new transitions are almost clear in the car, even in sunlight. I chose them to be non reactive when driving. If I need tints for driving I’ve got Polaroid varifocal sunglasses or clip ons.
Dec 27, 2022
549
397
2,135
As are my transitions but there is just a hint of shade about them even in the dark. Normally not a problem yesterday was an exceptional drive not my normal sort of thing, four hours without a comfort break😱
9,045
You might be in need of a good anti coagulant if you do stints like that. :eek:
5,231
I will be seeing my optician tomorrow for new spectacles. I was going to say new specs, but younger bodies not available. :LOL:
Our previous optician told me that spectacles that go dark in sunny weather could cause me issues and suggested anti glare? They do not work very well in bright sunlight and wet roads. I hardly ever drive at night and if I do, it is for less than 10 miles on dark roads, so I hope that is not an issue for me if I did go for the transition spectacles.
Unsure whether to to get the anti glare or the polarised spectacles? Not sure if there is a difference between polarised and photo chromatic spectacles.
9,045
You can by polarised fixed tint sunglasses to your prescription, Whereas photo chromatic can be ordered with polarisation too. I’ve found polarisation better than anti glare but you can also add an anti glare coating to transitions with polarisation too.. The link below details the different categories of Transitions lenses. I went for the Gen S as I didn’t need all of the extra features/ performance of the other types. Transitions are made by Essilor who invented the Varilux lens.
1,293
825
1,435
When purchasing these glasses do you use specsavers or a independent opticians? Roughly what price are you looking at? ( or not) . See what I did there 😏
9,045
We prefer to use independents as chain opticians operate as if you are lambs to the slaughter!
Ask if they do the deep eye scan (OCT), which scans deep into the eye a “ sees the future”, hence enabling earlier action if required. Mine detected a very limited area of MD, but at this stage nothing of concern, just ageing.
549
397
2,135
Started with Boots then Specsavers after that an independent.
The independent had a great ophthalmologist who spotted my Glaucoma, she has since gone to Specsavers so I guess I will be going back there next time but will possibly get my glasses over the interweb as I have five sets of old frames that need using.
Sam Vimes
2,563
2,058
12,935
First point.... I ditched my reactive glasses as I found them annoying. Not working in the car, not reducing reflections and slow to go back to normal. Instead I now use Polaroid over glasses. A little bit of faffing about taking them on or off as needed but a much better solution for me. Also saves money on the lenses.
Second point.... I use an independent optometrist. I can have the OCT, which has to be paid for because it's not covered by the NHS. My optometrist said it wasn't necessary in my case because my eyes haven't really changed in years and the NHS scan would be ok. Next year I'll go for it as it will have been about 4 or 5 years since last done.
Third point.... My varifocals, in titanium frames, anti-scratch, anti-reflection no reaction Zeiss lenses were £450.
Nov 30, 2022
1,954
1,835
2,935
Any transitional lens takes a finite time to lighten, and if going from a brightly lit road into a tunnel, or area heavily shaded under trees, that can be a serious issue, even if they go completely clear in just 2 seconds (which is very quick) at 60mph that still equates to over 50 metres travelled with impaired forward vision.
549
397
2,135
My glasses like many use UV to darken them, the cars windscreen removes UV so when driving they don't darken.
9,045
A reference stated that a front laminated windscreen will remove 95%-99% of UVA/ UVB , whilst the front side and rear windows will remove most UVB, and allow 60-70% of UVA to pass through. So it’s probably the side windows that cause transitions to darken when driving. This study was in relation to facial skin conditions of drivers where the side of the head nearest the window was the most affected.
Reference: Bernstein EF,Schwartz M,Veihmeyer Retal. Measurement of protection afforded by ultraviolet-absorbing window film using an in vitro model of photodamage. Lasers in Surg & Med 2006; 38(4):337-42.
9,045
Ordinary prescription sun glasses have the same problem too and do not lighten at all. My latest transition (Gen S) are designed for minimal response in the car, and thus far they’ve met the claims. Driving tonight was no concern, as UVA/B was obviously minimal. Tunnels of any length have lights, car headlights are switched on and short tunnels don’t get too dark in sunlit conditions. I got more concerned wearing any form of tinted lenses when going from sunlight in to roads with heavy leaf cover. Hence I would use clear lenses with flip up tints.
5,231
My concern is your mention of trees with leaf cover as we have a lot of that around here. Even with normal glasses sometimes it appears that your vision is impaired when going from sunlight into a shaded area. I am assuming that even a person with normal eyesight may probably have the same effect due to the make up of the car windscreen?
9,045
You are right on that one. I particularly noticed tree cover when travelling along the Fosse through Warwickshire famous for its leafy lanes. I guess that it is one more thing to think about and be aware of whilst driving.
Good luck sorting this lot out with the optician today. 🤞
3,535
Driving into the sun early morning or late afternoon is problematical whether you wear glasses, of any type or none at all.
5,231
Sadly I will need to cancel as a delivery that was supposed to happen yesterday has been postponed until today at about the time fo my appointment.
