Elddis Avante heavy nose weight.
Oct 9, 2013
I have just changed to an Elddis Avante 574 (twin rear single beds) and am having real issues trying to achieve a nose weight of under 100Kg! I can't use the front locker for anything other than a 6Kg light gas bottle and the storage under the lounge seats is also unusable if I am to achieve 90KG. The Elddis is a 2012 model and is as left the factory apart from the addition of a motor mover which was transferred from my Ace caravan. The motor mover was fitted by a main dealer and is fitted in front of the single axle as is the usual I believe! Is this the cause of the high nose weight and would it be worthwhile paying to have it moved to a position behind the axle? Will it make that much difference to the nose weight? The Ace had the same motor mover, fitted in front of the axle and was not a problem with the weight.
Does anyone have any experience of the Elddis issue or advise if moving the motor mover to the rear of the axle would help? I am concerned that the correct loading can't be easily achieved on this caravan so any advice would be welcome!
4,785
Hi Brian
sorry to hear of your problem.
Can you help the boffins on here by describing exactly how you are measuring the noseweight , what type of scales .I assume you are on the level. The height from the hitch socket to the ground you are using for measurement will also help.
With answers to these questions and there may be more from others I am sure we can find you a solution .
Oct 9, 2013
Dustydog, Thanks for the reply and some further detail is below as requested.
I use a Kampa Noseweight Indicator which was bought from Towsure. The description is as follows:
Noseweight gauge featuring a large easy read accurate scale, soft top prevents damage to hitch and has a great large stable base. This noseweight guide is fully tested for greater accuracy.
Spring centralising tube which stops spragging
Heavy duty metal construction
Calibrated to weigh between 50kg and 100kg
Size: 33 x 3.5cm
Piano wire Spring
Material: Aluminium
Weight: 500g
Colour: Silver
Before measuring the nose weight I have the van level, jockey wheel down and corner steadies up. Fit the Noseweight indicator into the Winterhoff hitch socket ensuring the van remains level. I use chocks under the gauge if required to keep the van level and then raise the jockey wheel slowly and let the gauge "take the strain" . This is always around the 100Kg mark and I only have the gas 6Kg light in the front locker. Nothing is in the front lockers inside the van and there is some minimal weight in the under bed storage at the rear of the axle. Pillows, bedding and a porch awning all stored as close to the axle as possible.
I used the same gauge on my previous Ace van and always found it useful and could store quite a lot in the front outside locker without getting close to 100Kg, in fact I could do this and achieve a desired nose weighting of between 70 and 75Kg.
Any help would be really appreciated.and let me know if any further info is required!
Apr 20, 2009
5,617
1,021
Brian, I was having the same problem with my Fleetwood.
Using a Pyramid gauge similar to your Kampa one.
Then I went back to the tried and tested old fashioned way of the bathroom scales.
This was showing a differance of 27 kg under the Pyramid, so I was actually travelling way above the permitted weight!!
I even went and bought another set of bathroom scales and they confirmed the Pyramid was reading 27 kg over.
My front locker now has 2 gas bottles, spare wheel, chocs, ramps,EHU cable and other bits and pieces, this is counter balanced with the rear underbed storage, 2 chairs, windbreaks and the aquaroll and wastemaster, hope this helps.
4,785
Thanks Brian
A very comprehensive explanation.
Back to basics for a moment.
Have you taken a nose weight measurement with the caravan empty but as delivered from Elddis?
Elddis shod be able to give you their factory delivered nose weight.
It will be interesting to see how that compares.
As far as I can see Elddis recommend a maximum nose weight of 100kgs.
Thus I'd be surprised if they sold an empty van with a heavier weight.
Generally it be a case of just balancing the see saw
3,984
Hello Brian.
I have towed many different caravans, some with what seems to be heavier than average nose weights, but I have always been able to achieve my desired nose weight either by rearranging the items in the caravan or by adding ballast for trim. I used to carry empty water containers, that I could fill and use to provide the ballast. In your case I suggest moving the awning and poles further behind the axle. Whilst this will increase the pendulum moment, we are only dealing with perhaps 20Kg so it should still be well within the control of the vehicle.
Unfortunately your method of measuring nose weight is not correct. The EU regulations require the nose weight of the trailer to be measured with the hitch at the same height as when it is coupled to the tow vehicle and ready to tow with all luggage and passengers. That usually means the caravan is not level, more often than not it will be slightly nose down, which will tend to increase the nose weight measurement which is why I said 'unfortunately'
The height of the hitch is important, because if you tip a caravan up or down from its towing angle the actual nose weight changes.
It is also unfortunate you have purchased a nose weight gauge because none of the commercially available gauges (at the time of writing) have the ability to be adjusted for towing height, which introduces an inaccuracy. Also as most of then simply use a spring in compression, t means depending on the applied load the length of the device changes the measurement height, another inaccuracy, and finally as far as I am aware only one manufacture claims their gauge is 'calibrated' but even then the graduations are so wide its difficult to make an accurate reading. Gagakev has already pointed out that his gauge was clearly far from accurate. So you can see I have a very dim view of these propriety nose weight gauges.
How To Measure Nose Weight
Nose weight will vary if you load your car or caravan differently. So you can only accurately measure your nose weight when you are set up with all your luggage and passengers and ready to tow.
Find a piece of horizontal ground big enough for your outfit
Park up and leave your loaded caravan coupled to the loaded car.
Measure and record the height of the hitch from the ground
Chock the caravan wheels and uncouple the caravan, release the caravan brake .
Place your measurement device under the hitch and adjust it to set the caravan hitch to same height as when it was coupled to the car.
Make sure no steadies or the jockey are touching the floor and then take your nose weight reading.
What can go wrong!
Well several things, the ground must be as level and horizontal as possible, any slope will affect the nose weight reading.
And at the time of writing, non of the retail nose weight gauges allow you to adjust their height to match the correct coupling height
And the majority of the retail nose weight gauges have coarse measurement graduations preventing you from making an accurate reading, and most of the gauges are not guaranteed to be accurate and repeatable.
So basically anyone who uses a retail gauge in practice cannot say with the required degree of accuracy what their nose weight actually is.
A Practical Solution
Fortunately there is a reasonably practical solution. Most of us already have a set of bathroom scales, which have fine graduations, and in all probability will be inherently more accurate than most of the dedicated nose weight gauges.
Find a piece of flat wood that will lie on the scales to protect them. either find some blocks or caravan step to raise the scales to the required height, or cut a length of broom handle to stand on the scales and wood, such that the hitch is supported at the required height.
You can also check the accuracy of your scales by loading then with known weights, for example take an empty 25 Litre plastic bottle, weigh it, then fill it with 25 Litres of water and re weigh it, The difference in the readings should be 25Kg
Oct 9, 2013
Guys,
Thank you all very much for the information and advice regarding my issue with the Elddis. I now have a lot to look into to see if I can resolve the issue. I don't have bathroom scales but will happily purchase a set. Hope I don't scare myself too much when I actually weigh myself though!!!!!
I can easily set up the van tomorrow and test the weight as suggested albeit as left the factory Plus the motor mover as I really don't fancy having to drop these. I don't believe a manufacturer like Elddis would supply a van that can't achieve their maximum nose weight of 100Kg, same as my car by the way.
I am sure that I can get it closer to where I would like it to be, around 75Kgs or so, when I follow the steps given by you all.
Thanks yet again for you all taking the time to reply with the valuable advice and I will let you know when tested tomorrow or Friday.
Thanks guys appreciate it all.
Apr 20, 2009
5,617
1,021
Made one of these you could make one yourself , and its adjustable for the heights.
It's Based on Sir Sprockets design
Jul 11, 2006
490
We are actually talking here of a major industry problem which it appears the manufacturers won't admit to or do anything about.
I have a 2010 Bailey Pegasus 462 which has a rated noseweight ex factory of 67Kg. How do you attach that to an Octavia which has a maximum ball load of 60Kg?
Thankfully I didn't buy the Unicorn 1 which is 88Kg ex factory - the (removable) ball on my Passat B6 estate is rated 85Kg and a the car is rated maximum of 90Kg. I note that in the Unicorn 2 the gas bottle has been moved to a new external access box behind the wheels. I would add that if you RTFM you will find that the Al-Ko chassis is only rated 100Kg maximum on the nose!
Having changed from a Pageant Majestic Series 5 we loaded up the Peg in similar fashion - noseweight 126Kg!!! We went and bought some Really Useful boxes and put everything of weight in them and put said boxes in the wardrobe which is in the bathroom at the back. With a bit more juggling around we ended up with 78Kg on the ball, which allow us to relocate some items (quilts and pillows etc) to eventually end up with 85Kg - and it tows like a dream.
Many people will warn of the pendulum effect if you have too much weight at the back, but in the last two years (we have only had the van since 11/12) we have been to the Pyrenes and to Alsace and not had a moments trouble.
3,984
Hello Woody.
First and foremost it is the drivers responsibility to ensure their outfit follows the rules and is safe.
Neither the car or caravan manufacture knows what combination of car or caravan any customer will choose, so they are not beholden to ensure compatibility of their products with each others.
Again it is the drivers responsibility to ensure the correct matches are made.
Any caravan manufacture that quotes a nose weight can only do so for the vans ex-works weight. They can of course specify the maximum allowed nose load, but the working nose load of a caravan is determined on how you load your caravan, and again its the drivers responsibility to trim the load to give the desired nose weight.
I know i'm apparently distancing caravan manufacturers from the problem, but legally that how its is. Morally how ever I do agree the manufacturers should do more to be helpful with nose load margins, by making vans that have a lower ex works nose load. But as I have stressed It's the drivers responsibility.
Ultimately if you don't like the ex works nose weight don't buy the caravan.
I have to comment that its unnecessary to use phrases that use or imply expletives in posts.
Oct 9, 2013
Sir Gagakev
I did a very quick test last night and compared the nose weight gauge I had with my new electronic bathroom scales. I loaded up the gauge with 60Kg and then measured the same load (garden edging by the way) on the scales and they measured 53Kg. I have a feeling that this will be even more of a gap with heavier loads when tried properly on the caravan as this is the real test. I don't expect the gauge to be linear in properties and may show more of a gap. I can come up with something using the scales and an adjustable rod to ensure the height is maintained as it should be (slightly nose down in my case). I intend trying this later today if I get the chance.
I might even get the chance to follow your photos and build a proper device which I can use to ensure total accuracy and build experience of the required distribution of weight.
Thanks yet again for your help, the device looks great and would be worthwhile fabricating.
Oct 9, 2013
Woody3 / Prof JohnL,
It is always nice to hear other informed views and I enjoyed reading both your latest replies. I do agree that it is the owners responsibility to ensure the correct loading is maintained, hence my original question! As a fairly new caravanner I was looking for some experienced views on how to achieve and maintain the correct weight distribution for my new van as my main concern is Safety. I am also convinced that no major manufacturer would produce a caravan that is inherently unsafe and can only state specifications such as nose weight as they know it to be which is ex-works. The responsibility to ensure I stay under the 100Kg max for the van and my car is mine. The safety of my family being the major factor for me of course.
You guys, and others, have pointed me in the right direction and I have a few things to try out as I said so thank you all again for your input.
Jan 31, 2011
316
When we bought our previous van Compass Liberte its nose weight was 110kgs :eek:hmy:
That was empty & on the dealers forecourt
3,984
Ahh but how was it measured?
Jun 2, 2017
141
yeezy boost 350
jerseys cheap
coach outlet online
heat jerseys
phillies jerseys
cowboys jerseys
hermes bags
discount nike shoes
oakley sunglasses outlet
michael kors outlet store
louis vuitton bags
yeezy boost
mont blanc pen
michael kors outlet
adidas uk
birkenstock outlet
louboutin pas cher
nike outlet
toms
burberry outlet online
kate spade handbags
purs jerseys
adidas outlet store
cheap jerseys
toms
coach factory outlet online
cheap nike sneakers
nfl jerseys
louboutin outlet
longchamps
air max outlet
ralph lauren sale
adidas running shoes
coach handbags outlet
birkenstock shoes
coach outlet online
true religion
pandora charms
fitflop shoes
nike outlet store
ralph lauren outlet
adidas nmd r1
yeezy shoes
air max
nike outlet store
coach outlet online
michael kors
coach outlet store online clearance
hermes bag
kate spade bags
moncler uk
versace
cheap jordans for sale
prada outlet online
ralph lauren outlet online
louis vuitton factory outlet
gucci borse
mont blanc pen
swarovski sale
coach outlet online
kate spade outlet online
mulberry uk
coach purses
jordans
tory burch outlet online
adidas outlet online
giants jerseys
adidas nmd runner
gucci outlet online
adidas nmd runner
adidas outlet store
yeezy boost 350
beats by dre
rolex replica watches
nike outlet
moncler uk
gucci handbags outlet
ralph lauren sale
coach outlet store
kd shoes
cheap jordan shoes
polo ralph lauren outlet online
sac longchamp
burberry outlet store
ralph lauren outlet
kate spade outlet store
harden shoes
pandora jewelry
pandora charms sale clearance
michael kors handbags outlet
polo ralph lauren
christian louboutin
dansko outlet
texans jerseys
ralph lauren sale
fitflops
fendi bags
air max 90
dodgers jerseys
eltics jerseys
louis vuitton outlet online
longchamp bag
rolex replica watches for sale
chaussures louboutin
nike free 4.0 flyknit
rolex watches
coach outlet store
yankees jerseys
montblanc
pandora charms
fitflops sale clearance
pandora
coach outlet online
nike free run flyknit
nfl jerseys cheap
curry shoes
ray ban sunglasses outlet
christian louboutin outlet
adidas nmd runner
nike air max 95
marc jacobs
christian louboutin shoes
adidas ultra boost
ray ban sunglasses discount
cheap jordan shoes
adidas superstars
hermes outlet online
oakley sunglasses on sale
cardinals jerseys
michael kors outlet clearance
abercrombie outlet
marc jacobs outlet
hermes outlet
cheap rolex watches
pandora charms
air max 90
nike free run
nike outlet store online
longchamp handbags
yeezy boost
true religion jeans
ralph lauren sale
tory burch sale
coach outlet online
fitflops clearance
air max
cheap jordan shoes
michael kors outlet online
nike sneakers
coach outlet online
yeezy boost 350
louboutin outlet
coach outlet online
gucci outlet online
air jordans
coach outlet store
discount oakley sunglasses
moncler pas cher
polo ralph lauren
mulberry bags
sac louis vuitton pas cher
coach outlet online
ray bans
michael kors bags
adidas
toms outlet
coach outlet store
michael kors
mont blanc pens
broncos jerseys
sac louis vuitton
birkin handbags
swarovski uk
fake rolex watches
clarks shoes outlet
wireless beats headphones
salomon boots
birkenstock outlet
ralph lauren
jordan shoes
fit flops
coach outlet store
louis vuitton outlet store
adidas nmd r1
gucci
red bottom shoes for women
mulberry handbags
adidas nmd r1
christian louboutin sale
swarovski crystals
ralph lauren outlet
rangers jerseys
mulberry outlet uk
mlb jerseys
true religion jeans outlet
pandora jewelry outlet
fitflops clearance
beats wireless headphones
burberry sale
bercrombie
tods outlet
fitflop shoes
cheap nike shoes
cheap nfl jerseys
kd 8 shoes
salomon outlet
nike outlet online
burberry outlet
michael kors bags
jimmy choo shoes
ed hardy store
fred perry polo shirts
cheap oakley sunglasses
valentino outlet
pandora charms outlet
air max shoes
nike store
dolce and gabbana outlet online
yeezy boost
toms outlet
fitflops sale
michael kors outlet canada
nike roshe one
gucci
49ers jerseys
moncler jackets
mbt
michael kors
ralph lauren outlet
adidas
yeezy boost 350
nike air max
yeezy 350 boost
michael kors bags
ralph lauren
patriots jerseys
adidas nmd r1
michael kors uk
coach outlet online
nike blazer low pas cher
pandora bracelet
nike air max 95
red sox jerseys
gucci bags
coach outlet online
air jordan shoes
nike flyknit
christian louboutin
mulberry uk
moncler outlet online
levis outlet
toms
nike roshe shoes
longchamp soldes
longchamp outlet store
hollister clothing
coach outlet canada
lakers jerseys
kate spade uk
longchamp bags
michael kors
ralph lauren sale clearance uk
moncler jackets
chi flat iron
jordan shoes
hermes bags
polo ralph lauren
mulberry
ralph lauren
clarks shoes outlet
coach outlet online
nfl jerseys
coach outlet
michael kors
mlb jerseys
adidas sneakers
longchamp bags
adidas store
hollister kids
beats headphones
nike cortez classic
tigers jerseys
warriors jerseys
pandora jewelry
salomon outlet
cheap air jordans
longchamp pliage
nike air force
michael kors outlet
louis vuitton purses
michael kors
nfl jerseys wholesale
adidas superstars
packers jerseys
longchamp handbags
fitflops sale
michael kors
red bottom
pandora outlet
white sox jerseys
fitflops sale
mbt
air max
clarks
nmd adidas
cheap ray ban sunglasses
coach outlet online
adidas yeezy boost 350
burberry outlet
cavaliers jerseys
air jordans
adidas sneakers
true religion outlet online
fred perry shirts
adidas trainers
polo ralph lauren pas cher
cheap jordan shoes
pandora jewelry store
red bottom heels
eahawks jerseys
ed hardy outlet
coach outlet online
louboutin shoes
nike uk
clarks shoes for women
parada bags
longchamp sale
yeezy shoes
bulls jerseys
moncler coats
nike outlet store
vans outlet
vans store
timberland boots outle
ray ban glasses
christian louboutin pas cher
cheap jordan shoes
rolex watches
jordan retro
yeezy boost
oakley sunglasses wholesale
nike tn pas cher
jordan femmes pas cher
rockets jerseys
cheap rolex replica watches
adidas nmd runner
montblanc pens
coach outlet online
gucci bags
birkenstock uk
adidas yeezy boost
thunder jerseys
jordan uk
louboutin outlet
birkenstocks
sac longchamp
ghd straighteners sale
adidas yeezy boost
coach outlet online
fitflop
adidas yeezy boost
birkenstock
celine outlet online
air max 90
fitflop
birkenstock outlet
ed hardy clothing
nike sneakers
fit flops
louboutin shoes
ray ban sunglasses cheap
ed hardy uk
adidas trainers
ralph lauren
chaussure louboutin pas cher
ghd hair
nike air huarache
ray bans
yeezy boost 350 v2
ray ban glasses
coach outlet online
coach factory outlet store
adidas superstar trainers
michael kors
polo ralph lauren
adidas superstar shoes
mlb jerseys whgolesale
pandora charms sale
tods shoes
birkenstocks
celine handbags
yeezy shoes
red bottom
kate spade outlet
kate spade bags
mbt
fitflops sandals
mlb jerseys
coach outlet online
cheap air max
longchamp bags
dansko
adidas sneakers
michael kors uk
adidas yeezy boost
cubs jerseys
ralph lauren uk
coach outlet online
fit flops
louboutin outlet
kate spade purses
pandora charms sale
cewcew4r
