electrical problem on abi jubilee 1990
Aug 24, 2007
hello there im new to caravanning and uinfortunatley in need of a little advice. we have an early 90's abi jubille pioneer
ill start at the beginning as its a little difficult to explain
i tested all the electrics prior to setting off on our trip hooked up to the house mains.
on arrival i had no power to the 12v side of the van when on site hook up 240v was fine. under the bench we have the 240 coming in to a rcd for 240v and a feed off to a grey box with logic 1 on the side with a red "mains on" rocker switch with a 5a fuse (blown) the leisure battery terminals are fed on the top of the unit and 2 20a feeds off to somewhere. now on my cupboard there is a small unit with 3 switches (awning light, pump, caravan/off/car switch and a battery power indicator)
possibly a zig style unit.
now i replaced the 5a fuse in the box only to have it blow when i switch the red rocker on.
just wondered where to start looking to fault find, could it be on the 12v or 240v side.
any help appreciated
thanks ian
Aug 24, 2007
is this a battery charger or a 12 volt transformer do you no?
hello there its a transformer/rectifier 240v in on a 5a fuse and 2 20a 12v outputs and also chargers battery, its a logic 1 make,
ive removed it and brought it into work for closer inspection.
think i may need a new one
