What an interesting turn these threads take ๐
Just back to the issue of keeping a tank powered to maintiain 70degC or having it on demand. As the Prof says there are too many variables to be able to have a definitive answer to this that fits all users. But here's something to consider.
Water at 70degC is, as the saying goes, "To hot to handle". You can spend all that energy heating the water to 70degC then go and add cold water at the point of use to make it usable for washing as an example.
There are at least two reasons that I can think of for having the tank stat set to 70degC.
1. To kill of Legionaires bacteria - although a temperature above 55degC would do this.
2. It makes the tank act as a thermal store. In other words if you have say an 150 litre tank of water at 70degC then by adding water at 10degC to this you'd get approx. 300 litres of water at 40degC. I say approx. because tanks dont have a uniform temperature throughout.
So, it could be possible on the days that the demand for hot water is low to have the stat set to something like 45degC. Then on the days when you need a lot of hot water - a couple of baths perhaps - it could be raised to 70degC in advance.
Other possibilities for savings also exist. Having a small volume localised hot water heater near the point of use for example. So instead of heating the full 150 litre tank to then run 5 or so litres of water into the kitchen sink, you could just have a small water heater in the kitchen area which you switch on when needed. Instantaneous hot water heatersare also a possibility but I've been disspointed with these in the past unless you get something powerful like an electric shower unit, which creates certain installation problems.
Saying that certain devices are not economical to use has no meaning unless you state what you are comparing it too. Also we have to consider the convenience factor. I could go down to the local burn and bang my clothes on a rock which would cost very little but the idea is not that attractive so I don't mind paying for a machine to do it.
Before trading in your working washing machine or whatever, do your homework. How much will you actually save by getting a better rated machine and how long will it take to recover the cost of the new machine.
