Electricity usage
Aug 24, 2024
18
Hi all.
I'm looking to finally get away for a week in the summer with our 1 year old.
I'm looking to go down to Devon.
All the sites I've found use metered electric.
I know its not something anyone can be specific on but generally what sort of usage/cost would I been looking
I have the basics In the van
Fridge, TV, lighting.
i do also have a air conditioner as the wofe gets too hot its apparently a low energy one designed for caravans its a Eurom AC2401 if anyone has one.
Any ideas on how expensive camping is going to be ?
Aug 19, 2023
24
13
515
I guess you need to look at the power consumption of each item, we have LED lights throughout so use very little but if you have anything else it will be less efficient, aircon will use 500 watts so will add up, fridge, toaster, kettle, microwave, oven battery charger etc, find out their power consumption and add it all up taking into account how much you will use it and then you can work out what it might cost you
Oct 19, 2023
480
367
935
It's a bit of a how long is a piece of string question. What I can tell you is that in summer me and Mrs Beardy use around 7-8 kW per day. That's 2 showers, another tank of water for washing up etc. Heating on for an hour in the morning and an hour at night and a split of electric and gas for cooking. Conversly, we were away for a short break a couple of weeks ago with the temperature dropping to near freezing over night (and not much higher during the day). The heating was on constantly while we were in the caravan. We used around 30 kW per day. The caravan sharing our EHU post used pretty much the same. Cost wise it will depend on the rate the site you stay on charges, it can vary quite a lot.
3,746
As you your self have said its difficult to be specific as it all depends on what item you use and for how long, that will give you an idea of the kWh energy you might consume, but that will vary with the temperature and the hours of daylight, and even if it rains.
However it is often simplest to set up and discover how much you have used (assuming you have a metered supply), then if its looking too expensive consider how you might reduce that usage without loosing comfort. Remembering to turn things off when you have stopped using them is a great start.
Often the most surprising appliances that seem to use more power than you might imagine, are lights, which tend to be used for long times, TV's also run them for 3 to 4 hours, and the power used begins to add up. Thankfully modern LED lighting and smaller TV's can be much better than halogen bulbs and older tV sets.
For some electrical items you might be able to choose or use the 12V ddc system which can reduce your peak loads on the 230Vac EHU.
Aug 24, 2024
18
just found this meter to plug in.
I could use it to measure how much i use with everything on and then calculate how much they'll charge me at the site
4,463
I think a question that needs to be asked is whether you are looking to go off grid or not. We have been to Devon on numerous occasions and have not used sites where each pitch is metered.
Last year we were in Devon and neither of the two sites had metered pitches. There are probably a lot more sites in Devon that do not have metered pitches than metered.
4,534
This is a useful Guide.
The site cannot charge you a greater rate per kwh than they pay.
In practice last September, it was cold so heating well used cost us just over £5 per night. The same site late Spring , warm, cost just over £2 per night.
Aug 24, 2024
18
I'm going to dawlish warren. Lady's Mile or Cofton
Aug 24, 2024
18
Although if you have recommended sites that don't meter I'd be interested in looking at those
7,741
Knowing what each item consumes is useful, but you don’t have them all on together you need to estimate a usage profile and we are all different. IE we rarely if ever had heat on overnight even in winter. But many do. Also we never left heating or electric appliance such as water heater in when we were out. If you use site showers that will affect your usage.
4,463
In the past 20 or more years never found the need to meter our consumption and we have been on sites where it was limited to 4amp, but we were still able to use the air con. Water heating and fridge were on gas.
After all when at home whether you like it or not, you still have to pay for electric usage so why worry about it on site as you are not using that electric at home? :unsure:
Sep 4, 2011
193
30
18,585
In all our 50+ years of caravanning we have never even thought of the electricity being used as we are using less than when at home. So we look at it this way as when away from home we are actually making a saving as very little is still being used whilst away. As we use super pitches we find that those with a meter where we swipe a card actually work out cheaper than the ones with Electric price combined in the pitch price.
2,805
On metered pitches, I work on the basis of 10 kwh per night - it drops to about 8 in a good summer and goes up to 12-15 in a cold spring or autumn - your aircon would add to that in summer.
Commercial sites will recharge electric at their commercial input rate which is roughly double that of domestic rates but some CL/CS are able to just charge their normal domestic rate.
4,463
Surprisingly our air con made hardly any difference to consumption. If using the heating facility on it, then it is using over 4amps which is why we never bothered with using it.
