Lennie said:
I have an Epson SX 425 printer and it requires new ink cartridges. I have always bought the correct Epson cartridges at great expense. Has anyone tried the much cheaper compatable cartridges of other manufactures for this printer to give accepable results.
hi Lennie,
to be brutally honest I would carry on using the correct cartridges if the printer is a good one, some of the replacment ones are not that good yes they work (sort of) but not to the correct spec for the machine, some functions will not work, ie refilled ones allways show the low ink levels, remanufactured ones dont use the same ink! so the consistancy will be different, and they can harm the machine,
I am on my 3rd printer, first one a lexmark was brilliant and very cheap untill the cartridge was empty the cost of a new one was more than the cost of a new printer, so I bought cheap replacements after fitting the printer shut down and would not restart, so it went into the skip.
second one a brother all in one "quite an expensive machine" used 4 cartridges of different colours each one was £10 each, again I sought a cheaper alternative and bought a refill pack, 4 weeks later the printer packed in, the print head had burned out due to the ink not being thick enough and had run all over the inside of the machine, skip no 2,
the one I have now is a HP 4500 series, and gets only genuine caridges it never lets me down and when the black runs low the program switches to mixed colour grey scale automatically something it would not do with a replacement cardridge,
it up to you but for my money somethings are not worth scrimping on printer cartridges is one of them.
