have been on solo and it looks really tight getting a van on .What is it like as I have enough Tesco vouchers to go on in february.
Thanks a lot
Thanks a lot
David,David,
It's easy - easier than driving a large car onto the double decker car-carriages - at each end of the coach and caravan train, there is a flat-bed wagon that gives you plenty of space to drive straight into the double height carriage.
Robert
I should of course have said "the train drivers couldn't get to their shift"I only hope you don't run into the same weather conditions that we had when we went through the tunnel in February 1996 (anyone remember the freak snowstorm we had on the 19th/20th of that year?). When we turned up at Folkestone around midday we found the gates of the terminal shut because there were no trains (the train drivers could get to their shift because of the snow) and we had to sit out in the cold until they let us in just after 4pm. In the end, the first train didn't leave until 6pm and that got stuck in the tunnel because there was so much melting snow on the vehicles that the airconditioning in the carriages played havoc and set the alarm system off. After being stuck in the tunnel for over 2 hours because of a technical breakdown in the train ahead of us, our train had to reverse back out again to make a second attempt. We didn't arrive in Calais until after 10pm. What was supposed to be a 45 minute journey turned out to be 9 hours including all the waiting.
I don't want to put anyone off using the tunnel but I just want to point out that it can also be affected by inclement weather, just like the ferries.
And what about the people who work for the Chunnel company?This land has a history linked to the sea and seafarers. If
we don't keep the ferries going what will the forces use if we need to protect ourselves again ?
Its a nice little relaxing cruise across the channel and gives a far more aestectic edge to start or finish of a holiday compared to tunneling under ;-0
Last year we arrived at Dover 1hr 55mins before our scheduled departure time and the "madame" on the arrival gate pointed this out to us. We in turn pointed out that we had towed a caravan 330miles and it was hardly possible to get the timing right.we are now thinking of beginning of March,spoiled for choice so as to speak.Is there somewhere near to Tunnel to stay ,have stayed in carpark by harbour in Dover with no problem but shame to drive past then back.May use ferry anyway,there is much to be said for both.
Hi David,del,what do you do to get vouchers used do they take numbers over the phone or do tesco deal with it.
Hi David,
I'll assume that the Tesco vouchers you have are relatively "new" I say this because I had an old
Thanks a lot for that,you did well to sort that lot out. will give it a goI forgot to mention that the Tesco code for converting your vouchers is the P&O code for crossing the channel.I know it doesn't mention Dover-Calais (its one of the Portsmouth sailings from memory) but you will be able to confirm with P&O at Dover that they do accept the tokens.
Well we don't need the French ones ;-)This land has a history linked to the sea and seafarers. If
