External locker strap
The rubber strap that supports the door of our external locker on our Adria is breaking. Anyone know where I could get a new one? Tried and failed to upload a photo. TIA.
Not familiar with the strap but does it have to be rubber?
I'd be tempted to take it off and pop down to a hardware shop and see if they have any alternative material that could be adapted to suit.
Probably cheaper to πŸ€”
Would not a piece of polypropylene or Nylon webbing, say 20mm be just as suitable?
The one in our Hymer is made of this type of material. You can get plastic buckles and metal D rings so avoid any need to sew it if that's an issue.
Or use a small ready made up rucksack or like strap?
eBay would be my starting point in researching the readily available options.
take a photo and contact seals+ direct they have a wide range of seals and are very helpful ,they are go to place for all seals concerned with caravans and M/homes
I got it wrong , I thought the poster was talking about the rubber seal , not the strap.
For the strap, which broke on my side locker door , I used a piece of that white nylon strapping that comes round heavy parcels , its only about 10mm wide but very very strong . I melted a hole in each end with a solder iron as I didn't want to tear the strand.
