External Pump
Sep 25, 2006
29
Hi
My the wire on my external pump is not long enough, does anyone know how to open the pump to replace the wire, or alternatively a safe way to extend the wire
4,324
Submersible pumps are usually sealed during their manufacture. It is not possible to fully replace the wire as that would compromise the seal around the motor, However you may be able to extend the wire provided you do it at the end that connects to the caravan. Make sure the the new connections are fully water tight.
Sep 28, 2007
13
Mod Note:
Potentially dangerous advice contained in post.
Therefore the posting has been removed
Damian (Moderator)
4,324
Stephen,
I cannot condone your, comments regarding electricity and water. Regardless of the supply voltage water should not be allowed to come into contact with any electrical connections. even with extra low voltages such as 12V or less.
