external water pump keeps running
The pump you insert into the aqua roll (I think it is a Carver) Thames pump, keeps running even when you shut off the taps
I have looked qqat the tap and can't see any wires to a micro switch but under one bunk is a whale pressure valve, I have tried to adjust this with the wheel on the top but the pump sutts off for a few second then starts to pulse on and off all the time
Is the pressure vale the problem?
Regards
Tony
