On my Adria I have what I believe is called a 'wet locker' at the front on the side where the awning goes. Inside there is a convenient 240V socket and I would like to fit a TV outlet so we can get TV in the awning. Problem is that the TV amp is on the opposite side at the rear so I don't want to run a cable all that way if I can help it.
Any reason I couldn't get at the coax going to the outlet opposite the door, and fit a splitter 'in-line' and then run a short length to the wet locker? Would I lose too much signal? I have a spare amp, identical to the one already fitted in the rear if I really need to use it.
