F.A.O. Chris Bonding Solutions
Feb 17, 2007
699
How many times can Bond-Tight be done-up/un-done, for example if it was used to secure a sat-nav to the dashboard which would be removed each time you left the vehicle, thus leaving less of a hint to villains than the tell tale round suction cup mark so often seen on windscreens ?
Feb 17, 2007
699
Chris,
Thanks for that. At present I have a Heath Robinson affair contrived from a plastic buckle - looks a bit like a motion sensor - but your product could be handy should I happen to get another car.
Feb 17, 2007
699
Hi Chaps
This Bond-Tight is it like blue Tack. I have the same problem with the suction cup mark on window. When you take it off does it leave a goo mess.
Regards Steve
Stephen,
Have a look at 'Help Needed' topic in this forum which will give you details of this product. It was reading that which prompted me to place my question directly to Chris.
