F.A.O Mr Sproket
Hi Simon
We have the 16.5 meter windbreak but you can buy as much / little as you want, some of the other members have now got a selection of setup's that they use ๐Ÿ˜‰
This is how big it is when set up with out the awning up.
When we away for a long break & if the pitch is big enough we put it to the front of the awning
This is the Kampa Rally Air 330 Pro ( 2014 )
with the small section of windbreak set up for the weekend
As you can see we use a full length draught skirt to stop escapeee's going under the van :lol: there is also a small gate to the right hand side. we lock it off with a bungee as well as the ground pin, it's a very sturdy construction ๐Ÿ˜‰
