Fenwick question
Sam Vimes
2,654
2,119
12,935
Does Fenwick's Caravan Cleaner remove squashed bugs or will I need something else.
I've accumulated so many over the last week it's affecting the nose weight ♥️
Jun 16, 2010
387
169
18,735
If you use some Bobby Dazzler after you've cleaned it, the insect corpses won't stick as well in future!
Mar 23, 2021
46
12
1,535
Fenwicks seems to move everything. Here’s a tip I learned; don’t bother buying any black streak remover- just use a little fenwicks caravan cleaner neat on the cloth and the streaks wipe right away.
2,697
If you can allow it to soak for a while most detergents will work. I use that method on seagull poo. A bit of wet soapy kitchen roll stuck to the offending area for 10 mins and it comes clean easily.
Reactions: figbat
