Fiberglass paint
My Casita 1983 folding caravan is is wonder condition except the white gas bottle box at the front which has yellowed and the surface is crazed. Any ideas about making it smarter? The box is fiberglass.
you need to go to a motorfactors/ chandlers and get some paint called polyester spraying filler, mix up as directions and spray on a couple of coats, if you dont have access to spraying equipment it can be brushed on you will just have a bit more sanding to do, once this is done and flattened down you need to prime it with a celulose primer / aerosols are available the flatten down again with wet and dry, then use your topcoat,
