Fire PCBTest.
Nov 17, 2005
87
The fire (Carver 4000 Fanmaster) in our 1999 Avondale Rialto 550-4 will work on gas with no problem, but we have lost the blown air/electric side of it, Does anyone know of a test we could use to test the PCB behind the fire please.
Thanks,
Jeff.
44
19,185
Are you saying nothing works on the electric side? or just the fan?
The most common problem is with the slide switch control, are all the lights glowing brightly and only one at a time?
To answer your question and taking pin one to be next to the slide switch connection.
1 variable voltage 3-10v depending on rear slide on switch,
2 12v supply
3 Variable as 1
4 0v (earth)
Any problems, www.arcsystems.biz
44
19,185
2 12v supply
3 Variable as 1
4 0v (earth)
Sorry, they are the fan connection voltages,
44
19,185
Hi Jeff, As the gas knob light and ignition is working it proves you have power up to the back of the main control box.
I've just checked a working unit and there is a permanant 0.163v on pins 1,2,3, (red, black & blue), of the slide switch loom. When switched on pins 4,5,6, (white, brown & yellow,) have varied voltages up to about 3.5V depending on setting. I've not got a duff switch I can test but I'd expect your's to show nothing on these last three but the first three will be the same at or very near 0.163v.
If I'm right then it looks likely the switch is faulty and will need repair which leads us to your last question.
I'm actually worldwide but much as I'd like, sadly unable to come in person, luckily though my postman Colin is a good intermediary!
Nov 17, 2005
87
Thanks for all your help Gary, today I recieved the switch back in the post to (southern Spain), installed it and i'm pleased to say my Carver Fanmaster 4000 now works like new again.
All thats left to say is a big thank you to www.arcsystems.biz and of course Gary.
Bye for now
Jeff.
44
19,185
Bye for now
Jeff.
Well thank you Jeff for your kind words, told you the postman does a good job!
