Hi All
Just got back from a few days away to try out running on battery only with a solar panel.
Was allowed to use a hook up pitch in case things went pear shaped!
The problem I had was running the van in 12v mode. The digital panel above the door would not switch on with out hook up attached.
Once I attached hook up, I pressed the caravan battery symbol and that lit up, then unhooked mains electric and away we went for 5 days. Tried at home to go on to battery only and once again panel would not turn on until I attached mains lead, switched panel on and then went on to caravan battery
As far as I know I am doing as the manual says, perhaps someone can point me in the right direction.
The control panel is a NE183-T56 used on Swifts as well I believe
Many thanks
Mike
Many thanks
Mike
