Fish when away.
We take our fish with us but , find difficulties changing the water after three weeks. Any tips please.
I guess bottled water wouldn't have chlorine in it and if left in the van its temperature would equalise to that of the tank. Also rather than changing the whole tank 25% refreshers might be less stress on the fish. Then the final 25% could be a top up with Adnams ๐Ÿ™‚
We just pop our fish into the aquaroll that has the mains water adapter kit fitted to it.
The fish are sort of 'trickle fed' with a fresh water top up on a regular basis and seem quite happy.
They do tend to blink a lot after several weeks in there (owing to the reduced light levels I assume) but recover quickly with no after effects.
I do put an extra fine gauze filter over the pump intake to prevent uneaten fish food and fish faeces going through the taps, the filter doesn't remove 100%, but a little does you no harm.
Change the water after 4 weeks........you will find it is much easier then.
The fish won't mind as they don't work to a calendar and have no idea what day it is.
The other thing is, Should I put a towel over them at night as the light from the fridge keeps them awake. I don't put them in the fridge. Before you ask.
Hutch,
I assume you leave the fridge door open to keep the caravan cool at night, I would just close the fridge door at night time and leave the windows and doors wide open.
If this would not work for you then you could move the fish to the under-bed storage area, or put them outside underneath the caravan if they are of the noisy variety.
Not sure about under the bed, as they like to watch the TV. Anyway here is a photo of Jaws, silver and Goldie.
Good that you posted this before mid day otherwise you wouldnโ€™t have received so many useful replies. Bring out the batter!
Aye, not the fridge in case they see the frozen chips and start to panic.
Did you guys REALLY fall for this? Now I know why the long weight was so effective.
We did have one guy ask for a wooden bayonet as it wouldnt glint in the moonlight. STABS, gotta love em.
