Fitting a Mini Heki Rooflight
Hi all,
I'm new to Caravanland and PC. I've just bought a Lunar Chateau 450 and the day after Storm Ciara blew off the roof light, smashing the top dome and breaking off the hinge.
I've discovered I need a Mini Heki Rooflight, but I'm not sure which roof depth size to order 25-42mm OR 43-60mm. As far as I can tell the measurement is around the 40-45mm mark, so my question is... Does anyone know for sure which version is the one to go for?
Also, a 2nd question if you don't mind, - after a service, I've learned the Zig X-70 battery charger is dead. Can anyone recommend a replacement?
Thanks in advance
In the majority of replacement roof lights I have fitted they have been the 25-42 size .
You need to clean off all the old mastic from the van roof and use a good bead of Soudall Fixall or Sikaflex 512 so that when you tighten the frame down it produces a bead around the whole of the edges.
As far as the charger is concerned I recommend the Sargent PX300, or you could contact Paul at Apuljack Engineering and get his to refurbish your Zig unit.
Many thanks Damian, I appreciate your reply. I do think this is the more likely option given the closeness in dimension. I will check out the Sargent charger too.
