FITTING A TV BRACKET
Hi folks, seeking some advice - I'm thinking of fitting this particular TV bracket to the underside of the overhead locker in the seating area of my Conqueror(2008), anyone else done something similar or got some wise words?
The above bracket looks a bit flimsy to me. I chose a more substantial wall mounted design, but because the caravan walls are not strong enough to take the load, I bolted it to two strong L-shaped steel brackets and those, in turn, to the underside of a shelf. You don't see the L-shaped backets though. It looks as though the TV-bracket is attached to the wall.
I hope that's understandable. Unfortunately, I can't make a photo of the arrangement at the moment because I've just taken my caravan to the dealer's for its yearly service tomorrow.
Hi Lutz, thanks for the reply. The specs for this state that it will fit TV's up to 32" and 13Kgs, it's more about where it is being fitted. If you get a chance, a photo of what you used would be appreciated.
Hi Steve
As Lutz say's it looks a bit flimsy, but your choice as what type you decide to fit
I fitted one of these under a cupboard in 2009 & we now use a 19" tv fitted with a quick release mount.
Quick release mount
I mounted it quite easily
These are the T nuts that the screws screw into ( i just put a mat over them )
Because it has a wide foot it supports the weight of the TV better
Just trying everything before final lock up
( I used a blob of aradite on the threads in the ' T ' nuts to prevent them coming loose )
Old 17" TV dvd player
It can be twisted, lifted or lowered for the best viewing position
( this was taken when it was just fitted )
Lots of free space now under the TV
This is a threaded ' T ' nut that i used
( i removed the spikes so that it laid flat as the spikes would have destroyed the shelf when digging in )
The shelf that i mounted it to in my van have a type of laminate top & bottom .....
Hi Sproket,
I like the look of the setup. The Quick Release Clamp is a definite item, as are the threaded T Nuts.
Have you got a link to the clamp you used as well, I can't recall seeing one quite like that.
I've got some other hurdles to overcome, and screwing it directly to the base of the cupboard is not straightforward.
Thanks very much for the links, I'll let you know how I get on - I'm sure you know this anyway, but the thought of drilling holes in my much loved van is causing me a fair amount of nervousness.
Hi Michael,
Thanks for the offer, however I've tried to click on your profile to email you, but I get the message not found - any ideas?
I got the caravan back from the dealer yesterday evening so I can now send you a photo of the setup:
data:image/png;base64,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
