After 2 long days i have managed to remove the cracked shower tray from my Sterling Eccles Coral. The old tray has 2 pieces of foam taped to the underside which i will remove and put under the new tray but this won,t make the whole tray sit flush on the floor of the caravan , which is why i,m guessing the original has cracked the way it has .
I,m thinking along the lines of using some sort of spray foam when i fit the new tray so there are no gaps underneath . Has anybody else tried this ?Does it work ? and if it does which foam spray did you use ?
