fitting towbar and electrics to citreon zantia
Jun 11, 2012
1,536
33
19,685
Francis if you are a bit tekki minded it is a diy able job the only relay you will need is a split charge relay to operate the fridge when travelling and when your not travelling.
this relay switches the fridge on when you start the engine and it switches the fridge off when you stop
I hope this helps in some way
Sir Roger
Aug 14, 2008
49
Hi francis, quite basic really, depending on towbar but all bolts etc ... should come with towbar & fitting instructions as for the electrics you will need a test light to pick up feeds from your rear lights,this is not difficult.there may even be the colour codes with the towbar to the light clusters, if dealer towbar purchased if you live in Nottingham i can do this for you, regards Terry
