Fitting TV Brackets
Jun 15, 2014
107
8
18,585
Hi all. I’d like to fit a TV bracket, but never done that in a caravan. Can I have some advice please. Thanks.
1,818
Looking at the manufacturers fitting in ours it is fastened into a thick dividing panel using the bracket manufacturers parts. Not tried it my self but it does need a good solid wall due to the weight it has to support.
I would not drive with the TV on the bracket though.
Oct 12, 2013
3,037
Same here , we are quite happy putting our tv on the drawer chest at the front if you've the option .
Jun 11, 2012
1,530
31
19,685
Our van has a swivel bracket already fitted and also swings out of the way for travelling where there is spring clamp to hold it firm while travelling The van is Sterling Elite Searcher . I think more info like what make is you van we may be able to give you more ideas then.
Sir Roger
Jun 15, 2014
107
8
18,585
Thanks Sir RogerFFS. Here’s a pic of the TV Point area (Red) and Shelf (Blue)
First time inserting a pic. Hope it worked :unsure:
The shelf isn’t that big, although we can stand our TV there. The TV 19”. The TV Stand itself takes up a lot of space, hence the Bracket route.
The board behind the shelf is thin. We don’t have a front chest.
I’ve considered a Toggle Fittings or strengthening panels, if I can get the same material. Are there special to type fittings?
Hope this helps.
Jun 15, 2014
107
8
18,585
Just discovered clamp on brackets. Might be the easy solution and we can easily take it down for travel:
Jun 11, 2012
1,530
31
19,685
Hi Fithawk. Ive just had a scamper through Ebay.sadly I have never been able to post picture on here so if you go to ebay put in these numbers in the search box 263268574422. Looking at your photo can you put a nice neat support board the other side of that area and then attach the ebay mount to it, basically thats all ours is.which was standard fit in our van . I hope this helps
Sir Roger .
Oct 12, 2013
3,037
Sir Roger .
Sir Roger , try this ;
https://postimages.org/
Select picture , let it load up , then copy the link 3rd from bottom i think (forum link) , then back to this site , paste link and should work .
