Does anyone know about caravan chassis technology c1997?
We have Elddis Genesis 3 with (I think) Al-ko chassis, the front and back ends of which have drooped about 50mm each, leaving the floor humped from front to rear - and therefore also crosswise amidships. The strain of the latter had caused the body sides to detach from the floor.
Because it's such a lovely caravan inside, I started engineering works to cure the hump and reattach the sides. We loosened the 3 sets of bolts that join the 4 sections (lengthwise) of the chassis, jacked the various bits up until laser-straight, tightened the bolts and welded the joints for luck, removed the jacks - and it went right back to sagged shape!
Further experimental jacking seems to confirm that the chassis is in fact incredibly flexible. Beginning to realise it's probably made of very high tensile spring steel, intended to flex like this?
Can anyone confirm?
I recall a caravan mechanic saying that these vans are intended to move/flex/bend at the bolted joints, because manufacturers found chassis fracturing if made rigid. I couldn't believe that, but now suspect he was half-right -
not that the bolted joints move/flex/bend, but if the chassis is high-tensie flexible, welding invites fracture, not because it make the chassis rigid (it doesn't) but because it affects the metallurgy.
So we have welded it - will it now fracture? (not so far).
How were these chassis set to start with - ends high so they'd flex to level under load?
How were sides supposed to stay connected to floor, when the flex causes the floor to strain up and down at the wall/edge?
Do these spring-steel chassis yield, to a permanent sag, over time? That's what's happened here.
Any wisdom much appreciated.
Can anyone confirm?
