Flexing chassis
Mar 12, 2017
10
18,510
Does anyone know about caravan chassis technology c1997?
We have Elddis Genesis 3 with (I think) Al-ko chassis, the front and back ends of which have drooped about 50mm each, leaving the floor humped from front to rear - and therefore also crosswise amidships. The strain of the latter had caused the body sides to detach from the floor.
Because it's such a lovely caravan inside, I started engineering works to cure the hump and reattach the sides. We loosened the 3 sets of bolts that join the 4 sections (lengthwise) of the chassis, jacked the various bits up until laser-straight, tightened the bolts and welded the joints for luck, removed the jacks - and it went right back to sagged shape!
Further experimental jacking seems to confirm that the chassis is in fact incredibly flexible. Beginning to realise it's probably made of very high tensile spring steel, intended to flex like this?
Can anyone confirm?
I recall a caravan mechanic saying that these vans are intended to move/flex/bend at the bolted joints, because manufacturers found chassis fracturing if made rigid. I couldn't believe that, but now suspect he was half-right -
not that the bolted joints move/flex/bend, but if the chassis is high-tensie flexible, welding invites fracture, not because it make the chassis rigid (it doesn't) but because it affects the metallurgy.
So we have welded it - will it now fracture? (not so far).
How were these chassis set to start with - ends high so they'd flex to level under load?
How were sides supposed to stay connected to floor, when the flex causes the floor to strain up and down at the wall/edge?
Do these spring-steel chassis yield, to a permanent sag, over time? That's what's happened here.
Any wisdom much appreciated.
I would think that the structural integrity of a modern caravan does not fully rely on the Chassis which is basically just 2 members held apart by the axle. Then bolted to this is the Laminated plywood floor, to which a laminated aluminium/ polystyrene/ thin plywood walls are fixed to with a front and rear end of GRP supported by some bits of 2x1 cheap rough sawn timber. Also the caravan is held together by all the internal cupboards etc.
Failure or weakness in any of the above and the thing is going to fall to pieces. The Floor is a major part in all this. How Strong and dry is your Floor?
Mar 12, 2017
10
18,510
Right - yes the walls/roof/floor would form a rigid monocoque box if they all hold together, and might then keep a springy chassis flat, provided the floor didn't 'dish' in the middle (but it has, bigtime). Even if that floor was still a factory-fresh bonded sandwich, I don't believe it capable of staying that flat, as 'outrigger' from the chassis rails, under the weight of roof and walls bouncing up and down on the end of that 'outrigger' - I doubt the shear strength of the middle 25mm of expanded polystyrene is anywhere near sufficient.
So I do think there's more to it than meets the eye, than 'the construction strength in a UK van is the van not the chassis'.
Thanks anyway - any further thoughts?
Maybe I will contact AlKo.
Yes Don't forget the older pre sandwich constructed caravans had a far more substantial box section and outrigger chassis
4,459
I suspect your consideration of the whole caravan body being a monocoque is probably correct.
A cardboard box when fully closed is much stronger than individual sides, so whilst if the floor of a caravan had weights equivalent to the weight of the walls just hung of the floor panel, it may not be able to adequately support it, but each wall and the floor and roof all add have certain strengths that mutually add to strength of individual panels when they are correctly bonded.
Inside a caravan there are also certain furniture elements that can also provide some additional rigidity to the structure.
The chassis is more of a space frame, and yes it will provide some strength its principally carrying the body. If the body is not rigid (i;e joints have worked loose) then I not surprised the chassis has sagged.
Mar 12, 2017
10
18,510
Thanks.
It turned out that the chassis sag was not because of loose chassis bolts/joints, but just bending - 35 to 50mm down at each end - without buckling. That being the case, I'm now guesing it's high tensile ('spring') steel.
Not the stuff you should weld, like mild steel. But we have welded.
So if anyone knows whether these chassis were in fact high tensile, and whether welding it makes fracture likely ...
4,459
fostertom said:
...So if anyone knows whether these chassis were in fact high tensile, and whether welding it makes fracture likely ...
I believe the chassis is bolted together mainly because the chassis manufacturer produces a catalog of parts that can be to some extent be mixed and matched to suit each customers requirements. It also means if the chassis becomes damaged parts can be more easily changed.
Certainly ALKO don't like additional holes being drilled into their sections, as doing so voids any warranty, claiming they're a stressed member and additional holes will weaken the integrity of the structure. How true that is in my mind open to debate, but it is the reason that caravan movers only use existing holes or use clamping to secure to the chassis.
I suspect that welding the chassis together will have locally changed the nature of steel, generally welding tends to harden or reduce the ductile nature of steel, and in high stress areas this could render it more likely to fail. It will depend on how extensive the area of the weld, but If the welds did fail, if the chassis is still bolted, the failure may have little effect on the integrity.
I don't think anyone on the forum can predict how likely it is you will suffer a failure, as it depends on how close the chassis is loaded to its limits, how much stress it will be subject to when being used. Such things are mainly down to the user.
Mar 12, 2017
10
18,510
Thanks especially to ProfJohnL for detailed replies - giving me additional thoughts. Also posdted same on a Aus forum, getting their perspective - like 'weld a new chassis under it'! so my own engineering doesn't look so excessive.
I had first tried pulling the bulged sides flat by a kind of aluminium exoskeleton but they refused to flatten - I realised because the half-height (kitchen) furniture was maintaining a right angle between floor and wall, and the 'outrigger' part of the floor in the area of the axle was sloping sharply downward. Hence discovery of the end-to-end sag of the chassis. Trying to flatten the chassis then failed, as described.
The Aussie vans' problems seem due to failed steel outriggers to the chassis, but ours has no such; the floor sandwich seems to be the outrigger which is supposed to not bend and so support wall and roof weight, assisted yes by similar non-bend wall sandwiches right-angle connected to floor by furniture! Though ours is not rotten, apparently the sandwich-bonding has failed, leaving floor and walls free to bend. Subsequent 'working' up and down ripped the walls' connection from the floor, forward of the axle. That is now all safely reconnected via the aluminium exoskeleton, but walls remain bulged, floor humped and chassis bent.
Mar 12, 2017
10
18,510
To help me understand (or confirm) what's happening - which I'm getting - thanks. Also, worry about having welded steel that maybe turns out to be high tensile.
Nov 6, 2006
731
5
18,885
A caravan engineer once pointed out to me many years ago, that caravans of that time could suffer a 'jacking' (his word) effect as they get older. That is, the action of suspension bumps causes the floor to bend downwards in the section between the chassis rail and the outer wall, since this section carries the furniture and other heavy units such as fridge, cooker, boiler and so on.
This did appear to be true since out old van suffered from this with, work surfaces that sloped slightly away from you and also a slight end to end bend as described by the OP, though that not to his extent.
It seemed to me that the areas affected were where the furniture was not full height , and therefore not fully bracing the wall to floor joint.
4,459
It sound like the caravan is more seriously damaged than you would like.
Certainly if the floor panel has effectively lost its internal bond between is its layers it will have lost a lot of its rigidity as a compound construction. Sponginess is a well known problem and there are well documented solutions to repair small area's in situ. But the larger problem you seem to have is a much more serious issue. And its not just related to the usability of the caravan, but also to its on road safety. If there is any freedom for the cabin to lift or sway when being towed, it might be construed as an unsafe load.
Please when posting bear in mind we are not mind readers, and matters that you might take as being common knowledge may not be so by readers. It helps if postings are clear about there intention or reasons.
Mar 12, 2017
10
18,510
chrisn7 I think that's right.
Prof, you guys are confirming most of what I've come to realise about the deteriporation.
But the floor and the 2 walls' exoskeletons are now strongly reconnected, albeit still distorted as described.
To correct the floor-edge droop, thus bringing the furniture upright, thus allowing the walls to come flat, we have a plan to sling 3 50x25 steel RHSs crosswise through existing cutout holes in the chassis rails, the ends of which forming outriggers to rigidly jack up and support the bottom rail of the 2 walls' exoskeletons.
Jun 1, 2012
43
I saw a caravan at my dealers a few years ago with the sides detached from the front of the chassis. They had taken on the insurance job to reattach the chassis. The owner had hit a speed bump rather too fast. Could the problem be damage rather than flexing. Even twin axle caravans are sort of triangular in their support points with respect to wheels and hitch so should not need to flex greatly..
Mar 12, 2017
10
18,510
Before I discovered that the sides had detached from the front half of the floor, I would look in the mirror and see the van gently nodding up and down as we drove along. Bumping around would have caused the progressive tearing-out of the connecting wood-screws. Now no more nodding - really solid, safe - but still sagged/bulged as described.
Jul 22, 2014
329
No way. HT steel would be far too expensive, hard to work with at the factory, and unnecessary. It will be made of normal structural steel, which is relatively mild stuff.
4,459
Hello Bryan.
What you say is correct to a point, provided the forces involved all lie in the same plane as the chassis, But in reality the forces move all over the place and in all sorts of directions. The most obvious forces re those associated with the vertical movement of the caravan. Then there are those associated with side loads from tuning corners which will apply a twisting load as the centre of gravity is above the plane of the chassis.
A company I worked for undertook some testing on a car and caravan outfit by having MIRA fit accelerometers and recorders to the caravan, and then towing it around one of their surface proving tracks. The recordings showed some quite alarming motions in all sorts of directions, which could be reproduced on a multi axis orthogonal vibration rig so that components could be endurance tested to destruction. The rig looked like a space shuttle simulator.
Jul 22, 2014
329
You have obviously put a lot of work, money and effort into this van which sounds to me like it still has very serious structural issues. You need to ask if it is worth it. You could probably buy a second hand example of the same type in much better shape for a relatively low price.
I would guess that the sides of the van are no longer firmly attached to the floor, as otherwise the shear strength (in the technical sense) of the sides would be supporting the ends of the floor as they should.
5,509
This is a very interesting problem that I am afraid is without resolution Imo .
A few on here will recall a case a few years ago involving an Avondale .
New a year before they went bust.
The side wall on the nearside pulled away from the floor leaving a gaping hole and rendering the caravan too dangerous to tow.
At the time I assumed , and still believe, it was a faulty manufacturing problem whereby the wall to floor screws were incorrectly installed.
We couldn't prove it and the owner dumped a three year old caravan, literally.
Other BPW and Al-ko chassis have been around for years and on the face of it done the job. I doubt the problem here is the chassis but more probably the caravan structure itself failing. No amount of welding will fix this.
Note the chassis are galvanised needing grinding to ensure a good weld.
So for me in 39 years this is the 2nd case I have heard of .Is it more common than we think?
Are the chassis inadequate or on the limit?
No idea but I'd be gutted if my caravan had this problem!
Jun 1, 2012
43
Hello John,
I agree there are a range of dynamic forces involved with a moving unit, my point is that a substantially rigid "box" is possible in a caravan, but more problematic with a 4 (or 6) point wheel layout as found in a motorcaravan..
4,459
BryanTheSnail said:
Hello John,
I haven't looked that closely at motor home chassis so I cant make an informed comment about them. But without any doubt caravan bodies and caravan chasis mutually supply strength and rigidity to each other.
Jun 2, 2017
141
yeezy boost 350
jerseys cheap
coach outlet online
heat jerseys
phillies jerseys
cowboys jerseys
hermes bags
discount nike shoes
oakley sunglasses outlet
michael kors outlet store
louis vuitton bags
yeezy boost
mont blanc pen
michael kors outlet
adidas uk
birkenstock outlet
louboutin pas cher
nike outlet
toms
burberry outlet online
kate spade handbags
purs jerseys
adidas outlet store
cheap jerseys
toms
coach factory outlet online
cheap nike sneakers
nfl jerseys
louboutin outlet
longchamps
air max outlet
ralph lauren sale
adidas running shoes
coach handbags outlet
birkenstock shoes
coach outlet online
true religion
pandora charms
fitflop shoes
nike outlet store
ralph lauren outlet
adidas nmd r1
yeezy shoes
air max
nike outlet store
coach outlet online
michael kors
coach outlet store online clearance
hermes bag
kate spade bags
moncler uk
versace
cheap jordans for sale
prada outlet online
ralph lauren outlet online
louis vuitton factory outlet
gucci borse
mont blanc pen
swarovski sale
coach outlet online
kate spade outlet online
mulberry uk
coach purses
jordans
tory burch outlet online
adidas outlet online
giants jerseys
adidas nmd runner
gucci outlet online
adidas nmd runner
adidas outlet store
yeezy boost 350
beats by dre
rolex replica watches
nike outlet
moncler uk
gucci handbags outlet
ralph lauren sale
coach outlet store
kd shoes
cheap jordan shoes
polo ralph lauren outlet online
sac longchamp
burberry outlet store
ralph lauren outlet
kate spade outlet store
harden shoes
pandora jewelry
pandora charms sale clearance
michael kors handbags outlet
polo ralph lauren
christian louboutin
dansko outlet
texans jerseys
ralph lauren sale
fitflops
fendi bags
air max 90
dodgers jerseys
eltics jerseys
louis vuitton outlet online
longchamp bag
rolex replica watches for sale
chaussures louboutin
nike free 4.0 flyknit
rolex watches
coach outlet store
yankees jerseys
montblanc
pandora charms
fitflops sale clearance
pandora
coach outlet online
nike free run flyknit
nfl jerseys cheap
curry shoes
ray ban sunglasses outlet
christian louboutin outlet
adidas nmd runner
nike air max 95
marc jacobs
christian louboutin shoes
adidas ultra boost
ray ban sunglasses discount
cheap jordan shoes
adidas superstars
hermes outlet online
oakley sunglasses on sale
cardinals jerseys
michael kors outlet clearance
abercrombie outlet
marc jacobs outlet
hermes outlet
cheap rolex watches
pandora charms
air max 90
nike free run
nike outlet store online
longchamp handbags
yeezy boost
true religion jeans
ralph lauren sale
tory burch sale
coach outlet online
fitflops clearance
air max
cheap jordan shoes
michael kors outlet online
nike sneakers
coach outlet online
yeezy boost 350
louboutin outlet
coach outlet online
gucci outlet online
air jordans
coach outlet store
discount oakley sunglasses
moncler pas cher
polo ralph lauren
mulberry bags
sac louis vuitton pas cher
coach outlet online
ray bans
michael kors bags
adidas
toms outlet
coach outlet store
michael kors
mont blanc pens
broncos jerseys
sac louis vuitton
birkin handbags
swarovski uk
fake rolex watches
clarks shoes outlet
wireless beats headphones
salomon boots
birkenstock outlet
ralph lauren
jordan shoes
fit flops
coach outlet store
louis vuitton outlet store
adidas nmd r1
gucci
red bottom shoes for women
mulberry handbags
adidas nmd r1
christian louboutin sale
swarovski crystals
ralph lauren outlet
rangers jerseys
mulberry outlet uk
mlb jerseys
true religion jeans outlet
pandora jewelry outlet
fitflops clearance
beats wireless headphones
burberry sale
bercrombie
tods outlet
fitflop shoes
cheap nike shoes
cheap nfl jerseys
kd 8 shoes
salomon outlet
nike outlet online
burberry outlet
michael kors bags
jimmy choo shoes
ed hardy store
fred perry polo shirts
cheap oakley sunglasses
valentino outlet
pandora charms outlet
air max shoes
nike store
dolce and gabbana outlet online
yeezy boost
toms outlet
fitflops sale
michael kors outlet canada
nike roshe one
gucci
49ers jerseys
moncler jackets
mbt
michael kors
ralph lauren outlet
adidas
yeezy boost 350
nike air max
yeezy 350 boost
michael kors bags
ralph lauren
patriots jerseys
adidas nmd r1
michael kors uk
coach outlet online
nike blazer low pas cher
pandora bracelet
nike air max 95
red sox jerseys
gucci bags
coach outlet online
air jordan shoes
nike flyknit
christian louboutin
mulberry uk
moncler outlet online
levis outlet
toms
nike roshe shoes
longchamp soldes
longchamp outlet store
hollister clothing
coach outlet canada
lakers jerseys
kate spade uk
longchamp bags
michael kors
ralph lauren sale clearance uk
moncler jackets
chi flat iron
jordan shoes
hermes bags
polo ralph lauren
mulberry
ralph lauren
clarks shoes outlet
coach outlet online
nfl jerseys
coach outlet
michael kors
mlb jerseys
adidas sneakers
longchamp bags
adidas store
hollister kids
beats headphones
nike cortez classic
tigers jerseys
warriors jerseys
pandora jewelry
salomon outlet
cheap air jordans
longchamp pliage
nike air force
michael kors outlet
louis vuitton purses
michael kors
nfl jerseys wholesale
adidas superstars
packers jerseys
longchamp handbags
fitflops sale
michael kors
red bottom
pandora outlet
white sox jerseys
fitflops sale
mbt
air max
clarks
nmd adidas
cheap ray ban sunglasses
coach outlet online
adidas yeezy boost 350
burberry outlet
cavaliers jerseys
air jordans
adidas sneakers
true religion outlet online
fred perry shirts
adidas trainers
polo ralph lauren pas cher
cheap jordan shoes
pandora jewelry store
red bottom heels
eahawks jerseys
ed hardy outlet
coach outlet online
louboutin shoes
nike uk
clarks shoes for women
parada bags
longchamp sale
yeezy shoes
bulls jerseys
moncler coats
nike outlet store
vans outlet
vans store
timberland boots outle
ray ban glasses
christian louboutin pas cher
cheap jordan shoes
rolex watches
jordan retro
yeezy boost
oakley sunglasses wholesale
nike tn pas cher
jordan femmes pas cher
rockets jerseys
cheap rolex replica watches
adidas nmd runner
montblanc pens
coach outlet online
gucci bags
birkenstock uk
adidas yeezy boost
thunder jerseys
jordan uk
louboutin outlet
birkenstocks
sac longchamp
ghd straighteners sale
adidas yeezy boost
coach outlet online
fitflop
adidas yeezy boost
birkenstock
celine outlet online
air max 90
fitflop
birkenstock outlet
ed hardy clothing
nike sneakers
fit flops
louboutin shoes
ray ban sunglasses cheap
ed hardy uk
adidas trainers
ralph lauren
chaussure louboutin pas cher
ghd hair
nike air huarache
ray bans
yeezy boost 350 v2
ray ban glasses
coach outlet online
coach factory outlet store
adidas superstar trainers
michael kors
polo ralph lauren
adidas superstar shoes
mlb jerseys whgolesale
pandora charms sale
tods shoes
birkenstocks
celine handbags
yeezy shoes
red bottom
kate spade outlet
kate spade bags
mbt
fitflops sandals
mlb jerseys
coach outlet online
cheap air max
longchamp bags
dansko
adidas sneakers
michael kors uk
adidas yeezy boost
cubs jerseys
ralph lauren uk
coach outlet online
fit flops
louboutin outlet
kate spade purses
pandora charms sale
bythy
