Floor Delamination
Mar 6, 2006
11
I have a small area of floor that is starting to delaminate. I understand there is a glue you inject through holes to re glue it. Is this correct if so what is it called and who sells it.
Thanks.
Mar 29, 2005
405
my version for what its worth
hi,delamination...frightening no if you set out your stall and take your time.this is not a two hour job as stated,when you have finished you will know why they charge so much at the caravan repair shop.i have just done ours a few months ago.i will go through the steps best i can.ours had gone in two places,next to the door entrance and next to the sink four feet away.you will find that delamination is where the floor is used most.ie next to the sink and the door entrance.first decide how much delamination you have,ie.2 feet (old school) or 6 feet,this information is required when you go to order your epoxi resin mix.one mix will cover about 3 feet by 3 feet.got mine from barrons
