Flowjet pump seeping water
Sep 27, 2020
41
Hi all just noticed seepage on my flowjet pump any ideas how to fix
9,673
Where is the leak coming from? They can be fully dismantled with spares available. Although when mine stopped pumping I bought a new one from a specialist pump supplier. It arrived over night delivery and at half the price of caravan outlets. It took ten minutes at most to fit it. Yet I had spent a couple of hours dismantling and cleaning the non functioning one. A fiddly job.
1,819
If you have the technical ability to do the job hen as otherclive says it can be done. I suspect that the problem might be freezing water in the pump if it has not been used since Winter, but it would need to be stripped down to see what the problem was. In our case we discovered this when away, yes we should have checked it first, so the only option was a new pump.
4,849
If it was mine, I would remove the pump, and inspect that leaking seam, if it doesn't come apart there, then rebond the joint with a sealant , that what I done with a house shower pump 5 years ago, a lot more PSI involved.
