flys
hi guys just started caravan again after a forced break. i have got a cheap swift challenger whic has had the plugs on
the inside of the window removed. this has lead to flys and small buggs climbing in between the 2 panes. is there some way i can get them out or will i have to live with them?. cheers mark
Unfortunately once in they are very hard to get out.
You could try using a vacuum cleaner hose over one of the bung holes and hope they get sucked out.
TheTravellingRooster said:
Hi to you both.Yes,but you probably don't want to hear it!.You could borrow my Pet Spider, she is very efficient at clearing up a tasty morsel.Dead or Alive.
Yes good idea, but then he would be left with a fat spider stuck between his window panes. A good conversation starter though, could even take it a stage further, spiders in the middle of one window and fish in another!
Stick to the vacum cleaner I think.
Yes,perhaps;but I had a senior moment(to many & to often)and hit the wrong tab before I could add:-the spider is on a fine non edible lead & it may be necessary to be prepared to open up the bung hole and fit a slightly larger plug.
Hi guys thanks for the replies. As the flys are all in 1 corner in each of the front
Windows I was thinking of drilling a small hole in the inner part and use a drinking
Straw and Hoover. Is it possible to drill the window without damaging it or am I
Asking for trouble.
