We have a drain pipe from the roof that goes into the ground to feed the main drainage. Around the bottom of the drain pipe is the hole for it to pass through. The flagstones have been cut for the hole, but there is a gap al round of at leats two inches on two sides and about 5 inches on the other. The one side is flush against the wall.
Due to our fault of having bird feeders up, we have a rat living down there and all else has failed to capture this rat. We do try and clean up after the birds, but this is not always possible and the birds tend to spill a lot of seed onto the ground. besides OH wants bird feeders up so who am I to argue.?
As we have dogs & the cat, we do not want to use poison or snap traps plus we would hate to poison and snap trap a bird. The cat who is normally very quick has not had any success as the rat dives down the hole. Next door cat has also had a go, but no success.
I was wondering if there is a type of foam that we could use to block up the hole. I was thinking of stuffing some wire mesh down the hole and then squirting some foam that expands and hardens on top of the mesh if there is such a foam? Any ideas thanks?
