Folding E bikes for Caravanners
5,523
Not for me but in general terms are these bikes UK complaint in your opinion?
Whilst it says EU compliant do we subscribe to the same rules still?
This thing , whilst folderable is massive and would barely fit the Tourareg boot !
I could look it up , but a neighbour has bought one. The tyres are on par with a mid range motor cycle!
3,861
I could look it but a neighbour has bought one. The tyres are on par with a mid range motor cycle!
I couldn't see anything in the specs that's not allowed in the UK - the motor is 250W and maximum speed is 25kph, both the maximum permitted.
4,176
1,909
Is this because you want a bike for off roading across sand and marshy terrain, given the balloon tyres, or are you looking for something more road and track friendly?
If the latter I think there are better options.
IMO, it is better to buy a bike to meet your requirements, so that's a starting point, what is its task?
Oct 8, 2006
2,095
751
We have Raleigh Stow-e-way bikes and apart from only 20in wheels* they are great. When folded we could get both bikes side by side between the rear wheel arches of our Passat Estate. We now have a Skoda Karoq and the bikes fit just as well in the same place. Given the Tig has the same basic chassis I doubt you would have any problems.
*If the last bike you had was a 26" or 28" wheel it will take you ages to get used to riding on 20inches. Most of all - if like me - when you look over your right shoulder to see where SWMBO has got to, when you look forward again you will likely be across the white line and even heading to side-swipe the kerb on the other side of the road (I talk of a country lane here!) A rear view mirror on the offside end of your handlebar is a must! Also visit Decathlon if you have one nearby and treat yourself to a cycle computer - BUT it must be Bluetooth linked to the front wheel sender as the usual cable is neither long enough** to reach from the handlebar to the front forks or long enough when you fold the bike. Cost is (was) about £25-£30 and the Li-Ion disc batteries (two) last a good six months of 'normal' use or even a year of light use.
** Assuming you are tall and have to extend the handlebar upwards... Also for me at 6ft 1in the saddle shaft is not long enough to get may legs comfortable when riding - there are max and min length markings on the saddle shaft. The retailer should be able to get you a longer shaft and swap it at no cost.
Finally you will also need a stirrup pump with gauge to pump up the tyres - they run at 45-55psi and are rock hard over bumps! Valves may be Schrader or Presta but a suitable pump will fit both.
Good luck.
4,176
1,909
E-bikes can easily initially seduce, its only by trying several that the strengths and weaknesses relative to one's own needs become evident.
I would strongly recommend you leave your credit card at home and go and try a few differing ones at those outlets that let you try them. Then having thought it through think about actually buying.
The Raleigh Stow-e-way is significantly different to the one in the OP and has wheels/tyres way more suitable for on road use. Try cycling them with the power switched off if getting back to the van with a flat battery is ever going to be encountered, that's telling!
4,176
1,909
Looks similar to the bikes various food delivery riders in our area use. It’s a weighty beast at nearly 40 kg.
At that whilst it might well be "foldable" it is not sensibly also "portable", in our context just as important.
My wife's, long since effectively mine, a 2016 Kalkhoff at 26 kgs is even with the battery circa 3 kg clipped out all I deem portable to lift into the rear of our Disco. That does not fold but is viable as transportable and throughout been so. I simply take out the front wheel to do so and it is carried clamped by the forks. It has proved to be a good buy, now 4000 miles in and did achieve over 100 miles range on its "eco" setting.
For much more practical portability I use a Brompton, though to keep the weight down to aid portability its a non electric one, though we are talking very different price point to the bottom budget OP bike. That I can take on a bus which greatly increases its practicality, like you don't have to cycle back to base or visa versa.
