Folly Farm Hard Standing screw pegs dont even hold...any ideas
Feb 2, 2024
143
25
585
We love Folly Farm in west wales everything you could ask for but for one thing we pegged out our awning with several types and lengths of rock pegs and none of them held before we return this year anyone got any suggestions?
Nov 30, 2022
1,782
1,627
2,935
So did you leave the awning erected over an extended period of time?? That appears to be the case in your original post, If so then I think you have an unrealistic view of what they are capable of, they are not inserted into any SOLID like concrete are they?
8,329
If the gravel is on top of sand then you will have problems. We were at Freshwater CMHC site and one very windy night our normal “screwed” rock pegs started to loosen and we were up most of the night just stabilising the awning. Next day we went to a nearby leisure outlet and bought some long steel pegs and they worked well, plus I used some extra guys too.
Feb 2, 2024
143
25
585
It went up on a Monday and we left on the Friday but it was put away on the Thursday but thanks for your negativity. All the best
Feb 2, 2024
143
25
585
Thank you for your help and positive reply
Nov 30, 2022
1,782
1,627
2,935
Sorry if you consider what I posted as negativity, but it wasn't very clear in your original post, and I had assumed, wrongly it turns out, that you may have left it erected for a long period unattended. Had I been aware of the information now provided then obviously I wouldn't have posted what I did. Hopefully you will get some better advice about suitable pegs.
Feb 2, 2024
143
25
585
No worries thanks
2,005
We had a seasonal pitch on a hard standing and found that the only pegs that stayed in were the straight 12 inch ones (got them from Halfords). If it was windy we double pegged where the awning was most hit by the wind as well. Think the substrate on the pitch was rather sandy.
Reactions: toad a caravan
Feb 2, 2024
143
25
585
thanks for advise
2,411
We got these from Go Outdoors Hi-Gear Hard ground tent pegs they are steel drive in pegs heavy duty still got them, so probably get more use in the future .
8,329
I used similar ones that had a “screw thread” along the shank, and they were hammered into the ground. But they were not long enough and not very effective on a pitch with a sandy substrate.
2,005
We have got the Ultipeg stuff. There is a knack to it but it saves considerable bending down.
1,029
389
1,435
I haven't used my awning yet but several years ago I used to go camping.I had a Coleman tunnel tent that came with the standard steel pegs,these were replaced for polypropylene pegs approx 12"" long,each guy rope shared three fastening points on the tent.I altered this method so that each fastening point had its own guy rope( a coil of bright green) was used .this increased the anchorage points.Later I upgraded the 9mm glass fibre poles to 12mm.K(its essential that the elastic rope isn't slack or the poles can become detached from each other).The tent was over 2mtrs high 3mtr wide 4mts long approx and not aerodynamic,it took a lot of adverse weather but always stayed up .pegs driven in at an angle, some when remove shaped like a banana when removed,I assumed they had hit an underground obstacle and deflected around it
4,759
We simply use the drill and screw pegs and always managed. The screg peg never bent. Sometimes we had to use a masonry bit to make a pilot hole. Worked for us and probably cheaper than buying that Ultripeg and we both have dodgy knees and issues bending.
Reactions: Eldorado
