Ford Escort
Apr 12, 2006
Does anyone have any idea what is the max weight of Caravan if there is one at all that the Ford Escort Zetec 1.6 petrol (5 door)can pull safely?
Oct 13, 2005
141
it will depend on exact year and model but it appears to be around 1200kg max thats van and contents
2,962
As Richard says, it depends on year, model and spec, but most Focus models were under 1200 kg kerbweight so 1000 - 1100 kg caravan weight would be more realistic. The 1.6 would also be a bit short of power to tow 1200 but should be ok at 1000.
Avondale currently do a 2-berth at 1000kg max but you may need to look to older caravans as they were lighter - this would open up your choice to 4-berths..
2,962
Sorry Derek, I did read your post I just forgot to keep brain engaged!
As cars have been getting gradually heavier I'm fairly sure that an Escort will have a lower kerbweight than a Focus so I imagine 1200 kg would be out of the question.
Oct 13, 2005
141
Derek
my apologies RogerL is quite correct, I keep forgetting that fords max towing weight is always more than the car, most escorts seem to be around 1096kg so thats the max you can tow but a safe weight would be 85% of that so about 930kg so you will have to choose carefully
Apr 12, 2006
Sorry for causing so much confusion, but its only when I read my posts that I realised that I had typed ESCORT and not FOCUS.
It is a Ford Focus I own, my Escort owning days are well behind me!
Thanks for the advice guys, so I am looking at a 1000kg van max?
Oct 13, 2005
141
if its a focus then it prob weighs around 1170kg so 85% is still around 1000kg but you could go as far as 1170 but dont forget thats total van and contents
Hi Derek,
I used to own a 1.6 Ford escourt Estate towed a ABI Dalesman with a boat type roof two berth MTPLM 1000kg , to be honest it was heavy going with a head winds lucky to get 50mph on dual carraige way, overtaking anything was a no no, changed to a 2 ltr car problem was solved.
Roy
