Freelander/Pageant
We have just bought a used Freelander with PCT towbar to tow our Pageant, which is fitted with an AlKo stabiliser. However the stabiliser handle fouls the spare wheel making it impossible to hitch up.Any solutions please so we can use our van!!
I tow using an Alko towhitch which uses the extended towball. I have found that on coupling up that approaching from the left side slightly when reversing (the spare is offset to the right)makes it easier.
Just fit a spacer onto your towball. This will give you the extra clearance to hitch/unhitch the Alko. Richard
This keeps on coming up not surprisingly.Alko have a new handle prototype on display at the N E C according to their add in CC mag.This seems to be like the top of bicycle forks with a pus on handle bit.Many people remove the transverse screw that holds the red handle and remove/replace the handle for the upright position.
I hitch up with the rear door open and then close it after the stabilizer handle is engaged. Have had no problems at all with this method.
Hi JD;
I had the same problem with my Jeep Cherokee. I changed the Alko Stabilizer for a Winterhoff 3000. Problem solved. Costs about
Apr 4, 2005
36
hi just read youe enquiry about freelander hitching.. i also have a freelander and tow a fleetwood garland. what i do after realising my towball catches is just hitch up on a slight angle to the caravan. it completely misses the towball and the alko stabaliser isnt affected either..hope it helps
